oskar27 Posted March 24, 2013 Report Share Posted March 24, 2013 Just changed my 17" winter tires to the 18" original 4 season tires which my Edge came with. I found the process pretty easy and the jack / wrench were also pretty good. In the last 20 years or so I always had VW Passats and always used to switch the tires myself with no problem. Now with the Edge I wonder if there are any tips / guidelines to follow. I apply some lubricant on the studs after I clean them and follow proper rotation. But my main question is how about the torque on the wheel nuts? Since these wheels are chrome cladded, is there a chance to crack the cladding if you over torque the nuts? Quote Link to comment Share on other sites More sharing options...
Eddie Man Posted March 26, 2013 Report Share Posted March 26, 2013 (edited) As I recall (not on front of my O&M manual), the lug torque specs are 100 ft/lbs. Confirm by checking your manual. I would not recommend using any sort of lubricant or anti-seize compounds on the studs or lugs as this would alter torque specs and binding affects of the nut-stud. If corrosion or dirt is an issue, just use a steel brush to clean them. As for the hub-rim surface contact, a steel brush cleaning and wipe down is good to do followed up with a lite coat of anti seize for future ease of removal. Hope this helps. Edited March 26, 2013 by Eddie Man Quote Link to comment Share on other sites More sharing options...
oskar27 Posted March 29, 2013 Author Report Share Posted March 29, 2013 Thanks Edge Man for the feedback, sounds good Quote Link to comment Share on other sites More sharing options...
