normcloutier Posted March 24, 2013 Report Share Posted March 24, 2013 I am wanting to copy my itunes music onto USB to use in my edge rather than stream the songs from my phone. Is there a way to do this in iTunes 11 or do I have to copy them from the source folder? Do the playlists appear when using USB? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 24, 2013 Report Share Posted March 24, 2013 iTunes Export. Free download - works great. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted March 24, 2013 Author Report Share Posted March 24, 2013 Is this a GUI type program? The only download I can find online runs a java exe. Do you have a link? Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 24, 2013 Report Share Posted March 24, 2013 What format are the music files, Norm? Quote Link to comment Share on other sites More sharing options...
Haz Posted March 24, 2013 Report Share Posted March 24, 2013 A GUI version of iTunes Export that runs under Adobe Air is also on that page and is directly downloadable here. Good luck! Quote Link to comment Share on other sites More sharing options...
normcloutier Posted March 24, 2013 Author Report Share Posted March 24, 2013 i think they are just standard mp3 unless iTunes saves them as something else. I can get songs onto the usb no problem. I was hoping to be able to use playlists and actually look at the songs stored on the usb to be able to select specific ones. Is this possible? Quote Link to comment Share on other sites More sharing options...
egar Posted March 24, 2013 Report Share Posted March 24, 2013 Normcloutier, you asked two questions in your first post - copy music and copy playlists. Copying playlists will need some type software as others have suggested to extract your playlists from the iTunes library files. I did want to let you know there is an easy way (no software required) to copy just the music to a USB or SD Card. I do this on my Mac, but I think same process would work on a Windows PC as well. For me, I just copy everything from "/Users/ed/Music/iTunes/iTunes Music" directory to the USB or SD Card. Works like a charm! Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 24, 2013 Report Share Posted March 24, 2013 Egar, that works great, but if you have more music than flash drive, it doesn't work. The easiest way is to just open the flash drive as a window. Highlight songs in iTunes and drag them to the flash drive window. It'll copy them, and you don't need directories or anything. Quote Link to comment Share on other sites More sharing options...
egar Posted March 24, 2013 Report Share Posted March 24, 2013 Thanks for the tip Dingo. That would have to be a lot of music not to fit on a large capacity flash. I've got a long way to go before I'll have to worry about that. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 25, 2013 Report Share Posted March 25, 2013 While I provided the above download link, I'm not an iTunes user nor a playlist maker. I obtain most of my music via SoundCloud, using the Search feature at the top of the page to locate a desirable song, or artist, or genre, with no signup required. I just copy the MP3s from my Temporary Internet Files folder to a flash drive and use the Shuffle setting in my vehicle to cause the musical sequence to be a surprise. Good luck! Quote Link to comment Share on other sites More sharing options...
Will S. Posted March 25, 2013 Report Share Posted March 25, 2013 Haz, how do you know all this stuff. Every tme I come on here, I learn something noew. Thanks for posting that link. WTG. Quote Link to comment Share on other sites More sharing options...
rurick Posted August 29, 2015 Report Share Posted August 29, 2015 (edited) Macbook Air Open iTunes and make a new playlist with your title - example PIRATES for Pirates of the Carib. Fill this play list with the songs you want shrink iTunes to 1/2 screen put thumbdrive into usb port and name it open finder shrink 1/2 size so both windows are visible scroll down to DEVICES to see thumb drive on itunes window open new playlist - EDIT, SELECT ALL drag all tunes to finder column - it gets a red outline - verify download is complete. Plug into MySync port - on my 15 edge it shows the name of the USB drive (PIRATES) as soon as I plug in. I did this with 2 different drives - the main one has 400 songs and the entertainment menu shows both USB names. Voice commands work to select ( USB PIRATES, etc). hope this helps NO file conversions just drag and drop. Edited August 29, 2015 by rurick Quote Link to comment Share on other sites More sharing options...
