rock7437 Posted March 23, 2013 Report Share Posted March 23, 2013 I recently went to the dealership for a scheduled maintenance but wanted them to check out some things that my MFT (no nav) in my 2012 Edge was doing. my list of problems were: 1) Whenever I got into the car and started it up the MFT would have to re-index and create speech commands for my music. Even though I never removed my ipod from the car 2) If i sat in my car while picking up my wife from work and turned off my engine and put the car in Accessory mode and listened to any device on USB. When i started it back up MFT would revert back to the AV mode and not allow me to leave for about a minute. 3) I could not access the outside keypad function to change, erase or edit any of my key codes. It would allow me to enter the master code but would not take prompt me with a screen to enter a new one or erase the old ones I had set up. The only way I could do that is if i reset the entire system and after I changed it I was unable to access it again. - So after the dealership took it in and initially told me my APIM probably was to blame. They said they got a message into ford saying that my MFT is in spec and that all the things listed above are normal. They stated that all MFT systems revert back to AV mode as the default when it is in accessory mode. and that a user is allowed one key turn per access to the door code. Mind you they never addressed the re-indexing. So my query is. Does this happen to everyone or is it just me that this is happening to. I dont have another MFT to go and test this out on to see if the dealership was just dicking me around or telling the truth. But if anyone can confirm or discredit the dealership's assertions I'd be extremely grateful because this is clearly annoying the hell outta me. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted March 23, 2013 Report Share Posted March 23, 2013 I have a 2013 which I have been recording some music onto a USB flash drive. I have been going back and forth with the drive to check on the recordings as I make them, and trying some different options to get the cover art to show. I have been putting the key (keyless ignition so really just pushing the button) until I get into the ACC mode. When I do, the last source for the radio (FM, XM, USB, etc) will start playing. It never reverts to AV. It does index and build voice commands but only for the first time the drive has been inserted with new music on it. Once it indexes and build the commands, it will not do it again until new music is added to it. I have added a code to the keyless pad on the drivers door, and have never had a problem with it taking the new code. I have never had to re-enter the code due to it not working more than once. I have nav, MFT, and the keyless start. Quote Link to comment Share on other sites More sharing options...
joesworld Posted March 23, 2013 Report Share Posted March 23, 2013 I have issues 1 & too as well. Hoping they'll be fixed by a software update, but I'm not holding my breath Quote Link to comment Share on other sites More sharing options...
CARR142 Posted March 23, 2013 Report Share Posted March 23, 2013 I have issues 1 & too as well. Hoping they'll be fixed by a software update, but I'm not holding my breath Hello joesworld, That would be one way all of us could solve Ford's problems with MFT/MLT . JCarr Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 24, 2013 Report Share Posted March 24, 2013 NONE of those issues are normal. Demand a new apim. Quote Link to comment Share on other sites More sharing options...
rock7437 Posted March 24, 2013 Author Report Share Posted March 24, 2013 Thanks for the advice guys. I'm gonna go to the dealership and insist they do that. This is silly for the system to do this Quote Link to comment Share on other sites More sharing options...
drpepper Posted March 24, 2013 Report Share Posted March 24, 2013 "When i started it back up MFT would revert back to the AV mode and not allow me to leave for about a minute." WRONG That doesn't happen. Every new startup I get the home screen. " have to re-index and create speech commands" common error BUT WRONG! mine doesn't. Make sure in the entertainment , usb, options settings u do not have it set to reindex. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 24, 2013 Report Share Posted March 24, 2013 "When i started it back up MFT would revert back to the AV mode and not allow me to leave for about a minute." WRONG That doesn't happen. Every new startup I get the home screen. " have to re-index and create speech commands" common error BUT WRONG! mine doesn't. Make sure in the entertainment , usb, options settings u do not have it set to reindex. How do you know what happens with someone else's vehicle? With MFT strange things can happen even if they shouldn't happen. Quote Link to comment Share on other sites More sharing options...
drpepper Posted March 25, 2013 Report Share Posted March 25, 2013 (edited) akirby- maybe my post was confusing. my WRONG! is for the this is normal. The OP stated..."They said they got a message into ford saying that my MFT is in spec and that all the things listed above are normal. So my query is. Does this happen to everyone or is it just me" So in reply to the BS from Ford & Dealer that those resultst are NORMAL I called BS on that! reverting back to AV is not with in spec- that is not how it happens on my car nor should it be re-index all the time is normal & with in spec- I call BS on that one! No it is not! But it does happen to many Edited March 25, 2013 by drpepper Quote Link to comment Share on other sites More sharing options...
akirby Posted March 26, 2013 Report Share Posted March 26, 2013 Ok - that makes more sense. Quote Link to comment Share on other sites More sharing options...
edge535 Posted March 27, 2013 Report Share Posted March 27, 2013 My MFT reverts back to the AV screen as mention above. it is very annoying never use to do that before. Also sometimes it says indexing with my iPod which is in the car 95% of the time. for as long as this system has been on the market, you would think all those little annoyance would have been solved by now. Quote Link to comment Share on other sites More sharing options...
