Can the interior dome light be turned off???
I hate the fact that I can't turn off my interior dome light. All my other cars past and present have always had the option of shutting off the interior lights. Am I missing something? At night, it's so annoying when the light goes on every time a door is open. I feel like I'm under a "spotlight" lol.
I own a 2013 edge sport awd. How can i fix this without removing a bulb or fuse?
  • 8 months later...
  On 3/10/2014 at 1:12 AM, candurin said:
You can always get the latch with lock mechanism from the mkx and install it in the edge. You just then need to have it keyed for your ford key. Solves one of your concerns...
The glove box is not lockable, also the light & switch are separate from the lock mechanism. FYI.
  On 3/10/2014 at 6:08 PM, candurin said:
Omar,
Read my last post again.
You buy the LOCKABLE mkx version and swap that out on your edge.
That solves one problem. The other (lighting), you're on your own.
Sorry for not being clear enough.
Expand
Is there a lockable version? I have an MKX, and it does NOT have a locking glovebox! It would be nice to have one.
  On 3/10/2014 at 9:47 PM, ls973800 said:
Expand
The glove box light in the MKX is not connected to the ambient lighting.
Edited by omar302
but the solution creates another problem. i know i can easily remove the bulb...obviously. but if i do that, i won't have the front interior lights on at all, which is also an inconvenience. i want the light on when i want it on, and off when i want it off. not always on, or always off. thats where ford dropped the ball. they don't give you the option. so your solution...isnt quite a solution. who wants to fiddle with removing bulbs every time you want the light on or off. imagine you had to do that in your house, bedroom, bathroom, etc. removing bulbs are an inconvenience...period. not a solution in my eyes. a simple switch like all other cars would have been common sense and a simple remedy.
Edited by fredro
  • Like 3
Yes it would. Another simple remedy is to just leave the light on all the time. It's not like the light hurts anything and most people want it on all the time anyway.
On my 2011 Edge, I pulled down the front dome light assembly (very easy), there's a 3 wire connector to the lights.
-Ground
-Dome/Door light
-Push Button Map lights
I cut the dome/door wire and put a switch on it. I mounted it through the headliner, in front of the light, near the windshield.
You can mount a switch anywhere if you want to rn the wires..
The same can be done with the rear dome light.
the push button map lights still work normally.
the rear cargo lights still go on with the doors.
  • 3 months later...
I agree with Fredro! There should be an interior override, like on most cars. In a tailgating situation, you wouldn't want the interior lights on the entire time you have the lift gate open. If you can find the wire feeding the light a switch would be relatively easy to install. I wonder if the wiring for the rear light is fed down the center of the head liner or does it run up the side pillar?
  On 8/9/2014 at 12:50 AM, PaulSchott said:
You must really love your car if your only complaining about the dome light. Thanks Ford for a great ride. Boo to the engineer who didn't think of a dome light off switch. It wouldn't be very hard to wire in a switch.
i don't love my edge, nor do i hate it. i like certain things of the car, and i dislike certain things as well. for the price, its a bit of a let down. also, the dome light isn't my ONLY complaint of the car. i have a couple of issues with other things, not a huge deal. but again, i wish i was "in love" with the car, and I'm not. I'm getting something new soon enough, and ill either trade this one in, or i'll hand it down to the mrs., or one of my kids. they seem to like the car more than i do anyway! lol
