rheller Posted March 15, 2013 Report Share Posted March 15, 2013 I have had HID's installed for about a month now. DDM 35watt with wiring harness. Problem I am having is about 1/2 the time 1 headlight will not turn on with the auto headlights on. Its random, not always the one side or the other. If I keep the light switch off of auto, they work everytime. what am i missing? Quote Link to comment Share on other sites More sharing options...
candurin Posted March 15, 2013 Report Share Posted March 15, 2013 (edited) You check to make sure the harness isn't melted? That had been a problem with the ddm harness (more with 55w kits, but couldn't hurt to check). Others have reported they used capacitors, specifically made for hid kits that had fixed the problem you're describing. I don't recall the exact post but you can search for it. Edited March 15, 2013 by candurin Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted March 16, 2013 Report Share Posted March 16, 2013 Check your grounding. Quote Link to comment Share on other sites More sharing options...
rheller Posted March 16, 2013 Author Report Share Posted March 16, 2013 My harness is still like new. no burning. I have it grounded to the battery....and is tight Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 16, 2013 Report Share Posted March 16, 2013 You need to ground each side, and may still need a capacitor. Quote Link to comment Share on other sites More sharing options...
rheller Posted March 16, 2013 Author Report Share Posted March 16, 2013 I got the wiring harness from DDM and hooked the ground to the battery. what wires from each side should be grounded? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted March 16, 2013 Report Share Posted March 16, 2013 Maybe try running them without the harness. The DDM harness is built really cheap with thin gauge wire that is way to long which adds a lot of resistance. My first harness was a cheap E-bay purchase that would only ignite one balast. I made a custom harness using 14 gauge wire for my 35/5000 DDM kit that works perfect but I don't ever use the auto headlight feature. I'll use the auto headlights for a few days to see if mine work properly. Quote Link to comment Share on other sites More sharing options...
rheller Posted March 16, 2013 Author Report Share Posted March 16, 2013 thats a good idea. I will try it without the harness, since it does have add extra connections and alot of wire, maybe it is the issue. Quote Link to comment Share on other sites More sharing options...
nickrosales Posted March 25, 2013 Report Share Posted March 25, 2013 Hey Rheller, There might be malfunctioning part/s or the connections are loose. You may want to check that. I bought mine at hidextra, i used to have flickering issues when I installed my kit. Not knowing that I would need capacitors/ cancellers for my Ford. Since I installed the capacitors, I never had any issues with my kit. I was in their facebook and I saw that they have a recent blog regarding capacitors & relay. You may want to check that out, reading won't hurt you anyway. Enjoy! http://blog.hidextra.com/hid-relay-capacitors-part/ Quote Link to comment Share on other sites More sharing options...
jeffarnold01 Posted March 27, 2013 Report Share Posted March 27, 2013 I have the same problem. It does not happen very often but it's really annoying when it does. I have tried two different DDM kits (55w and 35w) with and without the harness the 9006 Morimoto Elite HID kit with heavy duty relay harness and still have the problem. It's always the passenger side light when I have the switch set to auto and when it happens if i turn the lights off then back on both lights work. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 27, 2013 Report Share Posted March 27, 2013 See my earlier comment. Quote Link to comment Share on other sites More sharing options...
rheller Posted March 27, 2013 Author Report Share Posted March 27, 2013 I removed the DDM harness and hooked my 35w kit directly and have had zero issues in the past 10 days! So I inspected the harness....on the ddm harness 2 of the ground connections just pulled apart, I am going to go through the harness and solder all connections. I am fairly confident that was my issue. thanks Quote Link to comment Share on other sites More sharing options...
fishx65 Posted March 27, 2013 Report Share Posted March 27, 2013 I removed the DDM harness and hooked my 35w kit directly and have had zero issues in the past 10 days! So I inspected the harness....on the ddm harness 2 of the ground connections just pulled apart, I am going to go through the harness and solder all connections. I am fairly confident that was my issue. thanks R, unless you are going to increase the wire diameter of your current DDM harness, I would just run your 35w Hids without it. Don't want to see any meltdowns!!!! Quote Link to comment Share on other sites More sharing options...
candurin Posted March 27, 2013 Report Share Posted March 27, 2013 I do wish people would read all the posts on the sh!tty DDM harnesses. If you're going with 35W, go without a harness. If you're going to run 50/55W harnesses, build your owd or pick up a well made harness (e.g. TRS). 1 Quote Link to comment Share on other sites More sharing options...
