2011-2013 Edge Front "Fog" Lights
ls973800
I have a set of new front light assemblies which I believe will fit the 2011-2012-2013 Edge. These are the strip of LED lights which fit into the front bumper. These have never been used and have never been taken apart. No upgrades have been attempted on these and no wire harness comes with them. The Ford part number on the backs are
RH BT43-13B220-A Bag it came in says Part 1761791 BZL ASM U387 FRT RH SWITCH
LH BT43-13B221-A Bag it came in says Part 1761355 BZL ASM U387 FRT LH SWITCH
I'm asking $80.00 for the pair and that will include shipping to anywhere within the lower 48 states.
The pictures show reflections from the flash on the camera.
Edited by ls973800
  • 2 months later...
I really don't know if the wiring is in place or not.
Yes, I still have two sets of these and shipping would be $6.00
Thanks, Steve
PS- You can easily check to see if your Edge has may have the harness in place. Follow this link on how to remove your front bumper and the second video shows how to remove the vertical lights. Just pull back the wheel lining after removing the 3 screws in order to see what may be wired there.
http://www.fordedgeforum.com/topic/12810-how-to-remove-front-bumper;-2011-2013-models/?do=findComment&comment=99338
Edited by ls973800
  • 4 weeks later...
  • 4 months later...
