fmrcaptevil Posted March 6, 2013 Report Share Posted March 6, 2013 when a front row map lamp is turned on by pressing the outer edge of the clear lens, it will remain on until turned off in the same manner...(regardless of the passage of time, and/or subsequent use of the vehicle). Quote Link to comment Share on other sites More sharing options...
Haz Posted March 6, 2013 Report Share Posted March 6, 2013 Capt: I appreciate your observation and I am finding a different result. My vehicle's Battery Saver function shuts off the map light after 10 minutes, although opening a door reactivates the map light until the mechanical switch is cycled to OFF by pushing upward on the lens a second time -- as you describe -- or, another 10 minutes passes and the Battery Saver deactivates the map light once again. Good luck! Quote Link to comment Share on other sites More sharing options...
Waldo Posted March 6, 2013 Report Share Posted March 6, 2013 Yep, battery saver will turn it off after 10 minutes. Quote Link to comment Share on other sites More sharing options...
fmrcaptevil Posted March 6, 2013 Author Report Share Posted March 6, 2013 Haz and Waldo, you are correct...turns out a family member had opened and closed a door right before I came out and found one of the map lights on...(thought it had been on for about 24 hours)...should have waited 11 minutes before freaking out! Thanks Quote Link to comment Share on other sites More sharing options...
