Dawgs18 Posted March 6, 2013 Report Share Posted March 6, 2013 I am looking for a set for my 2013 Edge Sport. I just got the 35w 5k HIDs so I am wanting it to match. Anyone know of a good place to find these? Thanks Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 6, 2013 Report Share Posted March 6, 2013 I have a set. $20+shipping. Quote Link to comment Share on other sites More sharing options...
candurin Posted March 6, 2013 Report Share Posted March 6, 2013 http://www.vleds.com/bulb/3157-3156-led/switchback-led/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-ck-type-base-1-pair-b-o.html http://www.vleds.com/resistors/led-load-equalizer-resistors-turn-signal-blinker-fix-1-pair.html Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 6, 2013 Author Report Share Posted March 6, 2013 I have a set. $20+shipping. Are these comparable to the vleds that candurin posted? Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 6, 2013 Author Report Share Posted March 6, 2013 http://www.vleds.com/bulb/3157-3156-led/switchback-led/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-ck-type-base-1-pair-b-o.html http://www.vleds.com/resistors/led-load-equalizer-resistors-turn-signal-blinker-fix-1-pair.html Thanks. What is the load equalizer? Is it necessary? Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 6, 2013 Report Share Posted March 6, 2013 The ones I have are 6000k. They won't match. Quote Link to comment Share on other sites More sharing options...
candurin Posted March 6, 2013 Report Share Posted March 6, 2013 The resistors are NECESSARY or you will not be able to get the white lights working (amber will still work) due to the inherent voltage in the lines. They take 15 seconds to install (line up the wires and clamp the scotchloks). Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 6, 2013 Author Report Share Posted March 6, 2013 The resistors are NECESSARY or you will not be able to get the white lights working (amber will still work) due to the inherent voltage in the lines. They take 15 seconds to install (line up the wires and clamp the scotchloks). Ok so these would be the ones to get to match my retrofit ones I just purchased. My wife is so happy I got this car, lol. 1 Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 6, 2013 Author Report Share Posted March 6, 2013 Also the 2 bulb or 4 bulb? I am gonna get some LED tailights at some point...so should I get the 4 bulb? Quote Link to comment Share on other sites More sharing options...
candurin Posted March 6, 2013 Report Share Posted March 6, 2013 2 or 4 bulb what? You just need the 6 ohm resistors. My wife pretty much shakes her head ALL the time, so adding the mods to the car didn't make a difference in her opinion overall. Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 6, 2013 Author Report Share Posted March 6, 2013 If you go to the site it says 6 ohm 2 bulb or 3 ohm 4 bulb. Quote Link to comment Share on other sites More sharing options...
candurin Posted March 6, 2013 Report Share Posted March 6, 2013 Oh. 6 ohm. Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 6, 2013 Report Share Posted March 6, 2013 Mine are sold. Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 7, 2013 Author Report Share Posted March 7, 2013 They are on order. Will post pics! Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 8, 2013 Author Report Share Posted March 8, 2013 Got the VLeds but they didnt work? I hooked up the resistor and switched around LEDS for polarity and nothing. Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 9, 2013 Author Report Share Posted March 9, 2013 I have 3 wires. Blk, green in middle and purple on outside. I hooked up blk and green and nothing. I unhooked green and did purple. The white comes on but when turn signal is on it just dims not turn amber. When I turned around bulb the amber is on and when signal is on it does nothing. WTH Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 9, 2013 Report Share Posted March 9, 2013 Did you order the ck ones? Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 9, 2013 Author Report Share Posted March 9, 2013 V Leds Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 9, 2013 Report Share Posted March 9, 2013 Look at the part number. Is there a "ck" in it? Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 9, 2013 Author Report Share Posted March 9, 2013 Yes. It's the ones candurin recommended. http://www.vleds.com/bulb/3157-3156-led/switchback-led/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-ck-type-base-1-pair-b-o.html Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 9, 2013 Report Share Posted March 9, 2013 The edge doesn't use ck bulbs. You got the wrong ones. These are right: http://www.vleds.com/bulb/3157-3156-led/switchback-led/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-4157-1-pair.html Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 9, 2013 Author Report Share Posted March 9, 2013 Ugh...I just ordered what candurin linked me too. Oh well, honest mistake. I will send these back then. Thanks for help. Quote Link to comment Share on other sites More sharing options...
candurin Posted March 9, 2013 Report Share Posted March 9, 2013 (edited) Oh sh!t.... Sorry dawgs! I didn't realize I linked the CK bulbs. I meant to link the standard ones. Again, my sincere apologies. Edited March 9, 2013 by candurin Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 13, 2013 Author Report Share Posted March 13, 2013 Ok got my LEDs and they work great. I'll post a pic when it's a bit darker out. Quote Link to comment Share on other sites More sharing options...
Dawgs18 Posted March 15, 2013 Author Report Share Posted March 15, 2013 I will add a video tomorrow. They look great and when I get Dan's Britlites...oh yea! Quote Link to comment Share on other sites More sharing options...
