Smallest winter wheel size for Edge Sport AWD ???
Bigmarc
I'm running 17" Factory Edge Wheels on my 2013 Edge Sport AWD.
The stock tire size on the 22" Factory Sport Wheel are much larger (rolling circumference > 4%) than the 17" Factory Wheel/Tire Setup.
So be careful with that.
Since you will be going w/new Winter Tires, take the opportunity to size them closer to your 22" setup.
The tire size I am using is 245-70-R17 which is slightly larger (0.53%) in circumference than the 22" setup.
So far this winter, they have performed flawless (much more sidewall rubber w/meaty treads)!
Edited by Eddie Man
