tpm419419 Posted February 25, 2013 Report Share Posted February 25, 2013 (edited) Hello all I have a 2011 Edge Limited. The backup camera lost it's warning markers (the lines plus the shaded in area). I did a master reset but no luck. Does anyone haver a fix for this without going back to the dealer? I do have the latest software and it worked for quite a while with that software. Also today while backing the camera screen went upside down, very strange. And I had times when the camera didn't come on at all Any help is much appreciated Thanks Ps. I checked all the appropriate camera settings Edited February 25, 2013 by tpm419419 Quote Link to comment Share on other sites More sharing options...
akirby Posted February 25, 2013 Report Share Posted February 25, 2013 Also saw that reported on an Escape. Seems to be a MFT bug. Hopefully it will be fixed in a future release. 1 Quote Link to comment Share on other sites More sharing options...
AmyLovesHerEdge Posted June 26, 2013 Report Share Posted June 26, 2013 June 26, 2013 My Edge is doing the same thing. No marker lines when backing up. Wonder if one of the sensors back there is out? Camera works fine. I rebooted Sync & checked the settings. Markers are set to display but not working. Backup warning beeper still sounds. Amy. Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted June 26, 2013 Author Report Share Posted June 26, 2013 On my 11 Edge the camera itself was bad.(yes the image was working most of the times but the lines would never come on) Had a TSB on early 11 models Quote Link to comment Share on other sites More sharing options...
Tacyon Posted June 27, 2013 Report Share Posted June 27, 2013 Besure that the safety zones are not turned off in the software. This suddenly happened to me and I was reminded by a few users here that there is a enable/disable setting. Mine decided it suddenly wanted to be disabled. Re-enabled it and that was that. http://www.fordedgeforum.com/topic/12029-f29-reset-back-up-cam-has-changed/?do=findComment&comment=92084 Quote Link to comment Share on other sites More sharing options...
AmyLovesHerEdge Posted October 23, 2013 Report Share Posted October 23, 2013 Dealer fixed the warning markers. If I understood them right, they said they had to reboot the camera module. They also updated MSFT to the latest update while they replaced the Power Transfer Unit for leaking gear fluid in between fixing the gear shift so the Park light comes on. Ha. Warning Markers lasted exactly 3 shifts into reverse. Now they do not come on again. I checked the enable/disable setting. At least the camera works, but those warning markers are handy in tight spots. The Shifter not going into Park lasted a little longer - 5 days. They fixed the linkage. SSM44164 But it is not working again either. Sigh. Car has barely 20,000 miles. I have only averaged between 5 & 7k miles a year. It hasn't been used hard. Now the transmission is acting funny going from 1st into 2nd. It bangs sometimes when it shifts. Man how I loved this when it was new. Amy Quote Link to comment Share on other sites More sharing options...
RJG Posted October 23, 2013 Report Share Posted October 23, 2013 Check your settings. On my 2012 I can turn the lines off or on. Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted October 23, 2013 Author Report Share Posted October 23, 2013 I had this issue on my 2011 Edge. They had to replace the actual camera which solved the problem Quote Link to comment Share on other sites More sharing options...
rwolson Posted October 23, 2013 Report Share Posted October 23, 2013 Replaced in my '11 too after the last upgrade Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted October 23, 2013 Author Report Share Posted October 23, 2013 I believe they said it was an issue with early build units. Mine was built in Sept. 2010 Quote Link to comment Share on other sites More sharing options...
AmyLovesHerEdge Posted October 24, 2013 Report Share Posted October 24, 2013 I checked the enable/disable settings on the screen. It should be showing the warning lines. I rebooted MFTouch also. The Dealer repair report said they rebooted the camera module. This actually fixed it. But it only lasted about three times before it quit working and never to be seen again. Yes, it's an early 2011 model. I think it was manufactured Oct-Nov 2011. My concern is the transmission now. It has begun to shift really rough in the low gears. Guess I'll start another Topic here to see if anybody is having this problem. Amy Quote Link to comment Share on other sites More sharing options...
AmyLovesHerEdge Posted October 24, 2013 Report Share Posted October 24, 2013 Sorry - I meant it was manufactured Oct-Nov 2010 not 11. 1 Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted October 24, 2013 Report Share Posted October 24, 2013 This is in setttings on the left side LCD display. You can also set if you would like a delay in the camera shitting off after you shift to drive, with delay it only stays on for an extra second as youre driving away. Quote Link to comment Share on other sites More sharing options...
