rwolson Posted January 30, 2013 Report Share Posted January 30, 2013 Hello, I'm looking for some advice. Tonight, on the way home from work I encountered a strange issue. When I select the Travel Link Weather Map I see a map briefly then the screen returns to the home page. Also, saw a msg indicating unable to read Nav SD card. I can select Navigation on the screen, but sometimes after a pause while Nav loads. Hit Weather Map again and you're returned to home screen. Strange! Before I hit the gym I loaded the Delayed Reboot App you can download from here http://outofmytouch.com/reboot.html I received my orignal on our Ford Edge forum immediately after someone posted it. The reboot didn't fix the problem. Next, performed the dreaded Master Reboot; I hate losing all of my Nav waypoints. I need to re-enter them AGAIN after I think, I forget how many times. The master reset seems to help for a bit, but my Nav system now wants to default to a location in Detroit until the GPS syncs. Also, the Weather Map's back to it's tricks returning to the home page. If I select my home waypoint the Nav sets the map correctly. My question, do any of you recall where to set our default weather location adn maybe a default home location? I recall Garmins request your home territory during the setup mode and if you move you can again change the home location. Yes, it's different from your actual home waypoint. I looked in the Touch PDF, but so far, no joy. I'm fortunate because I didn't run into the continous MFT problems other guys did, but to date dealer replaced a dead APIM, bad radio front panel which turned my heat up to max and flaky key fob. BTW, I'm running MFT 3.5.1 and A4 SD card. I upgraded over a week ago without any problems except a few why did they code it that way. I thought about playhing fuse 29, but we know how much we all like trying to find the fuse when wearing glasses. Thanks, Rich Quote Link to comment Share on other sites More sharing options...
rwolson Posted January 31, 2013 Author Report Share Posted January 31, 2013 Four total delayed reboots and the system's working correctly again. No idea why I ran into the strange problems. Quote Link to comment Share on other sites More sharing options...
gearheadgraham Posted May 6, 2018 Report Share Posted May 6, 2018 ok i am new to the ford edge but here goes i bought mine used its a 2011 edge sel and i dont know if it came with navigation or not. i have the a5 card and i tried it but it says no device when i plug it into the sd card slot in the console is there another place for the nav sd card? how do i know if it came with nav originally? when i click on the compass it has the where am i button but it does nothing. also the 911 asist doesnt work??? Quote Link to comment Share on other sites More sharing options...
akirby Posted May 6, 2018 Report Share Posted May 6, 2018 In the upper right does it say Information or Insert SD Card? If it says Information you do not have NAV. Quote Link to comment Share on other sites More sharing options...
