Tapping factory amp output
  On 2/15/2013 at 2:11 PM, akirby said:
You can tap the speaker wires for speaker level outputs or use an adapter on the back of the head unit to get line out.
Does the adapter allow you to tap without cutting wires? If I tap at the rear of the headunit, will I lose the sync voice over?
Edited by dummptyhummpty
  On 4/12/2013 at 1:07 AM, akirby said:
Try crutchfield.
Thanks, but this doesn't seem to apply to my Edge. I reviewed the wiring diagrams that have been posted on this forum and it looks like the sync signal and balance control is done by the AMP. I have located the connectors used on the wiring harness and amp, but I'm not sure how easy it will be to obtain them.
