Running Boards Installed
Kitulu
It took me a little longer than I expected to install. The nut plates that Dee Zee uses are a PITA when tightening down the bracket mounting bolts, I ended up using a 45 degree screwdriver and a long Allen key to brace the nut plates.
Putting the boards on the brackets was easy. Place the bolts through the holes, slide the board to where you want it, then tighten the nuts.
I also discovered that, if I am too heavy on the gas when backing off the ramps, the Edge will fling the ramps across the garage... :peelout:
Those are pretty sharp and I usually don't care for running boards. That's a nice design though.
I don't really use them much, they are more for my wife. She is barely 5' tall so now it is a little easier for her to get in and out...although it does make it a little easier to wash the roof, lol!
