ianm31 Posted February 12, 2013 Report Share Posted February 12, 2013 Yeah, I guess format wasn't exactly the best word to use.. Is this common with these systems? It just seems like an extreme step.. My previous car (G35) didn't have updates like this... Quote Link to comment Share on other sites More sharing options...
ls973800 Posted February 12, 2013 Report Share Posted February 12, 2013 Well, I'm starting to see several different "bugs" now that I've been running 3.5.1 for a while. Several times when I go to change the music source by using the center entertainment button, a black box with a circle saying NO DISC and a line through the words appears. It goes away after a minute or two. Sometimes when restarting the car with the USB left in and having been listening to the USB when I shut off the car, the USB starts with the first file, not the one that was playing when I shut it off. The center dash entertainment area will say USB and what song is playing, but the small info area to the right of the steering wheel will say AV AUX LINE IN or something to that wording and have a picture with 3 cables. I can scroll through the menu and USB is not even listed as an option. The Aux symbol stays in place even when I touch the entertainment quadrant and get the info on the large screen for the USB and what is playing. After a minute or two the small screen will finally show the USB and the song info. Sometimes the Grace notes shows the correct album art work, and sometimes only the generic art work will show. If I use voice commands to browse the USB for albums, it will list them OK. If I try to play one of them by touching the listed album on the screen it will usually not play. I have to use the touch control to browse the USB to list albums, and then I can touch the album I want and it will play. In the 6 months of ownership before doing this install I had the system only once go into the black screen with Scheduled Maintenance performed. After this last update, it has happened at least two or three times a week! There are times my phone does not pair with the system. I have to go into Phone settings and connect my phone. I can say that after this update I have had numerous problems or bugs that I've never had before. If I had it to do over, I would just stay with the 3.2.1 version I was running. I did this update because of the new navigation card, thinking it was a good way to get an updated map source. WRONG! Quote Link to comment Share on other sites More sharing options...
djgcue Posted February 12, 2013 Report Share Posted February 12, 2013 Well, I'm starting to see several different "bugs" now that I've been running 3.5.1 for a while. Several times when I go to change the music source by using the center entertainment button, a black box with a circle saying NO DISC and a line through the words appears. It goes away after a minute or two. I've had this "issue" but I discovered I was touching the 'eject disc" button inadvertently. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted February 13, 2013 Report Share Posted February 13, 2013 (edited) I've had this "issue" but I discovered I was touching the 'eject disc" button inadvertently. Thanks, I'll pay closer attention to see if I'm doing the same thing. I don't think so, but I'll make sure one way or the other. I might even just load a disc in there and see if the message continues. Edited February 13, 2013 by ls973800 Quote Link to comment Share on other sites More sharing options...
