TheWilldog Posted January 13, 2013 Report Share Posted January 13, 2013 Some ne'er-do-well decided to forcibly shorten my Edge's antenna mast. Now I left with this little nub. http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2423_zpsb8afd85c.jpg How does one replace this piece? Is it possible to just replace the mast, or do have to replace the whole unit? Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted January 13, 2013 Report Share Posted January 13, 2013 Can't really see much of anything from that pic whether it damaged the base or not.... would kinda need a close up pic from the backside angle to really see. But the mast just screws in there, as long as you can get the old one out and the threaded part in the base isn't damaged, just get a new mast Quote Link to comment Share on other sites More sharing options...
TheWilldog Posted January 15, 2013 Author Report Share Posted January 15, 2013 (edited) The mast is broken down to the base. I don't think I can get any pliers on it. Closer pic below: http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2428_zps25aa303b.jpg Edited January 21, 2013 by TheWilldog Quote Link to comment Share on other sites More sharing options...
candurin Posted January 15, 2013 Report Share Posted January 15, 2013 Can you access the broken, threaded piece of the antenna? If they broke the base of the unit, then you're SOL and need to likely drop the headliner to replace. If you can get out the remaining threaded portion of the broken antenna, then a replacement is very easy to do (and is a separate part/mast). Quote Link to comment Share on other sites More sharing options...
TheWilldog Posted January 21, 2013 Author Report Share Posted January 21, 2013 Can you access the broken, threaded piece of the antenna? If they broke the base of the unit, then you're SOL and need to likely drop the headliner to replace. If you can get out the remaining threaded portion of the broken antenna, then a replacement is very easy to do (and is a separate part/mast). I don't see an easy way to get at it from inside the car: http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2433_zpse0f4008d.jpg How much work is dropping the headliner? Quote Link to comment Share on other sites More sharing options...
TheWilldog Posted January 21, 2013 Author Report Share Posted January 21, 2013 I don't see an easy way to get at it from inside the car:http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2433_zpse0f4008d.jpg How much work is dropping the headliner? Aha! I was able to get a hold of it. Tried a different pair of needle nose pliers. I'll go hunting for a new mast, thanks. http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2434_zps743348c8.jpg Quote Link to comment Share on other sites More sharing options...
candurin Posted January 22, 2013 Report Share Posted January 22, 2013 Great news! FYI, you can swap the antenna for one from a mini (do a search on the forum). Zero signal loss and a much smaller antenna. Looks stock. Quote Link to comment Share on other sites More sharing options...
Mark94 Posted January 22, 2013 Report Share Posted January 22, 2013 Sometimes I hate being part of forums... I didn't even notice how ugly the antenna was until I read this thread and searched on the forum to find Dingo's recommendation of the mini antenna. Looks like I'll be spending more money before we even take delivery of the truck. The shorty does look much better though... Quote Link to comment Share on other sites More sharing options...
Dingo Posted January 23, 2013 Report Share Posted January 23, 2013 Dingo rocks. He has made me spend a ton of money, though. 1 Quote Link to comment Share on other sites More sharing options...
Manish R. Patel Posted February 21, 2013 Report Share Posted February 21, 2013 Cravenspeed is a good company for these, I bought one for my Xterra some years ago, solid product with excellent reception. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 21, 2013 Report Share Posted February 21, 2013 Dingo had mentioned Cravenspeed in another thread. So, in your experience, is the antenna indeed brush and carwash proof? Quote Link to comment Share on other sites More sharing options...
