Replacing the antenna?
Can you access the broken, threaded piece of the antenna? If they broke the base of the unit, then you're SOL and need to likely drop the headliner to replace. If you can get out the remaining threaded portion of the broken antenna, then a replacement is very easy to do (and is a separate part/mast).
I don't see an easy way to get at it from inside the car:
http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2433_zpse0f4008d.jpg
How much work is dropping the headliner?
Aha! I was able to get a hold of it. Tried a different pair of needle nose pliers. I'll go hunting for a new mast, thanks.
http://i289.photobucket.com/albums/ll204/thewilldog/Edge/IMG_2434_zps743348c8.jpg
Sometimes I hate being part of forums... I didn't even notice how ugly the antenna was until I read this thread and searched on the forum to find Dingo's recommendation of the mini antenna.
Looks like I'll be spending more money before we even take delivery of the truck.
The shorty does look much better though...
  • 5 weeks later...
