frazi Posted January 13, 2013 Report Share Posted January 13, 2013 I just completed my install of a DDM 35W HID kit (9006.5000K) and have a few questions. They look white from outside the vehicle, but they do show a bit blue in from the driver's seat. On my first drive this evening, four on-coming drivers flashed their brights at me (10p in heavy rain). I checked alignment pre and post drive, and everything was exactly in line with stock. Does this seem normal? I am concerned that they may be too bright for on-coming traffic. Any advice, suggestions or comments? Thanks, Mitch Ps: Thanks to kc300c for the step-by-step video. It was very helpful. Here's the link: Quote Link to comment Share on other sites More sharing options...
Lowery89 Posted January 13, 2013 Report Share Posted January 13, 2013 I have the same kit in both my vehicles and I don't get flashed alot... The rain may have added glare off the road to be a little more annoying to the on coming drivers... But when I do get flashed I introduce them to the sun! 1 Quote Link to comment Share on other sites More sharing options...
Edge_Beast Posted January 13, 2013 Report Share Posted January 13, 2013 I just completed my install of a DDM 35W HID kit (9006.5000K) and have a few questions. They look white from outside the vehicle, but they do show a bit blue in from the driver's seat. On my first drive this evening, four on-coming drivers flashed their brights at me (10p in heavy rain). I checked alignment pre and post drive, and everything was exactly in line with stock. Does this seem normal? I am concerned that they may be too bright for on-coming traffic.[/url] I had the same blueish hue from my ddm 5k bulbs and hated it. I Went with morimoto 5k's bulbs keeping the ddm ballast. No blue hue what so ever. A nice crisp white. As far as alignment, you can always lower them a bit if on coming traffic keeps flashing at you just my .02 cents Quote Link to comment Share on other sites More sharing options...
fishx65 Posted January 13, 2013 Report Share Posted January 13, 2013 I had to aim my headlights a little lower after installing a DDM 35/5000 kit in my 2011 SEL. It took me a while to get used to the type of light that HIDs project but now I really like it. We are very lucky that our halogen projectors work well with HID bulbs because not many do. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted January 13, 2013 Report Share Posted January 13, 2013 I dropped my headlight height as well after installation. Never get flashed. For $30 you can order order the 4300 and have a crisp diamond white color that's brighter than 5000k Quote Link to comment Share on other sites More sharing options...
frazi Posted January 14, 2013 Author Report Share Posted January 14, 2013 Thanks for the help, guys. I'll try lowering them a bit tonight ahead of tomorrow morning's commute. Quote Link to comment Share on other sites More sharing options...
frazi Posted January 16, 2013 Author Report Share Posted January 16, 2013 Thanks again for the help. I lowered the lights and haven't been flashed since. Thanks for the advice Edgieguy. I ordered a backup set from DDM with the 4500 bulbs. Thanks again! Quote Link to comment Share on other sites More sharing options...
MikeyDubs Posted January 16, 2013 Report Share Posted January 16, 2013 I'm looking into getting a set of 6000k HIDs for my headlights n figs. should I get the 35w or 55w like kc300 is running in his video? Quote Link to comment Share on other sites More sharing options...
candurin Posted January 16, 2013 Report Share Posted January 16, 2013 (edited) 55W you'll need a wiring harness (to take the increased load off the factory, smaller gauge wiring). 35W you can do without, which simplifies the install. Having said that, some will still recommend a harness for either application (but you will see plenty of members running 35W with no harness and zero issues). 6K will be more of a blue/white color. You sure you want to go with that? 55W will be be brighter and provide a whiter hue in the 6K bulb, whereas 35W will definitely be more blue. I personally wouldn't go higher than 5K. Edited January 16, 2013 by candurin Quote Link to comment Share on other sites More sharing options...
MikeyDubs Posted January 16, 2013 Report Share Posted January 16, 2013 55W you'll need a wiring harness (to take the increased load off the factory, smaller gauge wiring). 35W you can do without, which simplifies the install. Having said that, some will still recommend a harness for either application (but you will see plenty of members running 35W with no harness and zero issues). 6K will be more of a blue/white color. You sure you want to go with that? 55W will be be brighter and provide a whiter hue in the 6K bulb, whereas 35W will definitely be more blue. I personally wouldn't go higher than 5K. I have 8k in my f150 but want something with just a touch of blue so thats what I was thinking 6k. With my 06 f150 I needed a harness because the lights were flickering so I might get the harness just so I dont run into the same problems since im looking to do the fog lights also. What would you recommednd the 55w or 35w? Is there that much of a diference and what do regulare HIDs com 35w or 55w? Also how are the quality of the DDM tuning HIDs? Quote Link to comment Share on other sites More sharing options...
