Slick56 Posted January 1, 2013 Report Share Posted January 1, 2013 The passenger side seat belt is catching and then tightening. Very annoying. Is there anything that can be done? Is this the way it should work? Thanks Quote Link to comment Share on other sites More sharing options...
Mark94 Posted January 3, 2013 Report Share Posted January 3, 2013 Do you park the truck on an incline/decline? If it is, that could be the reason why it is catching as the mechanism inside is not balanced and free. Seat belt mechanisms are designed to recognize the slightest jolt or imbalance so if the car is hit or in an accident, that imbalance is what triggers the belts to tighten keeping you and your passengers safe. I had to remove the rear seat belt mechanisms to install a coilover system on one of my former cars and it was such a pain getting the mechanism to be perfectly balanced and free so I could reinstall the mechanism and belts. If that is not your issue there has to be an issue with the internal mechanism where it may be hung up on something causing it to catch periodically. Mark Quote Link to comment Share on other sites More sharing options...
Slick56 Posted January 19, 2013 Author Report Share Posted January 19, 2013 Is it repairable or replacable? Still under warranty. Quote Link to comment Share on other sites More sharing options...
Tacyon Posted January 19, 2013 Report Share Posted January 19, 2013 My drivers side belt does this (on right hand turns mostly) and ratchets me down into the seat. I have to exhale and scrunch down to get it to release. If someone discovers a "blue pill" fix, I to would be interested. Quote Link to comment Share on other sites More sharing options...
