cpufixer1 Posted December 24, 2012 Report Share Posted December 24, 2012 We have a 2012 edge limited. We leave the headlight switch on auto. But there is no where on the dash does it display if the headlights are on or off. This is a real pain when it rains. Here in NY there is a law that your headlights have to be on when your wipers on and I never can tell when the auto features turns the lights on. Quote Link to comment Share on other sites More sharing options...
Dingo Posted December 24, 2012 Report Share Posted December 24, 2012 They turn on with your wipers. Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 25, 2012 Report Share Posted December 25, 2012 ^^ What Dingo said. When headlights are set to auto, they will turn on when the wiper are activated. Quote Link to comment Share on other sites More sharing options...
a43472 Posted January 6, 2013 Report Share Posted January 6, 2013 On my 2013 Limited I also have the lights set to auto and I think that the indicator that the lights are on; is two little headlights pointing away from each other under the left information panel, they are real small but I assume that what is going on. Unable to locate these in the manual. So I'm just guessing. Not sure if you have these on yours. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 6, 2013 Report Share Posted January 6, 2013 Might be a 2013 thing? My 2011 does not show anything except when the fogs are on. Quote Link to comment Share on other sites More sharing options...
Scorpio Posted January 6, 2013 Report Share Posted January 6, 2013 A quick check of those coloured lighted rings in your cupholder (along with those other interior accent lights) will also tell the tale - if they're on, your headlights are on. This is with the lighting package with the Limited anyway, not sure about other models. Quote Link to comment Share on other sites More sharing options...
Kitulu Posted January 13, 2013 Report Share Posted January 13, 2013 The dash lights and nav should also dim. If you have the foglight on, you should see that indicator on the switch illuminated. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted January 13, 2013 Report Share Posted January 13, 2013 I have a 2013 Limited with autolamps which I leave on and rain sensor wipers which I leave on. Today I was driving in what started as a light mist and it was quite overcast. The wipers would cycle every 30-40 seconds, but the lights never came on. I hit some heavy rain which caused the wipers to cycle every 10 seconds or so and the lights finally turned on. I didn't like the fact that the lights didn't turn on because of the overcast conditions or that the wipers didn't cycle quick enough for turning the lights on. I wish the autolamps had a sensitivity setting to adjust how dark or dim it really needs to be in order for the lights to come on. There have been times that I have switched the lights on manually because I felt it was too dark or overcast to drive without the lights on and the autolamps had not turned them on yet. I believe I can put something over the sensor to turn them on. I wonder if I could put some type of mesh material over it to allow for quicker turn on in less light but not have them on all the time. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 13, 2013 Report Share Posted January 13, 2013 Maybe you could put some lightly tinted film over the sensor? I don't have MFT, so I can't speak to this directly. But it seems there are sensitivity level settings through MFT for other lighting functions for the headlamps. Worth a look? For example, this discussion on another forum re: auto hi beams --- http://www.ecoboostownerforums.com/showthread.php?1480-Not-so-auto-High-Beams Otherwise, a trip to the dealer may help if this is a malfunction. Quote Link to comment Share on other sites More sharing options...
c_bova Posted January 13, 2013 Report Share Posted January 13, 2013 (edited) The wipers have to go three times in a certain time to get the auto lights to kick on. The way I tell if my lights come on when it rains and isn't dark are the ambient light rings in the cup holders. Edited January 13, 2013 by c_bova Quote Link to comment Share on other sites More sharing options...
akirby Posted January 13, 2013 Report Share Posted January 13, 2013 Some people have added window tint film to the sensor. I think someone found a small tinted plastic cone. It should work but it would be trial and error. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted January 13, 2013 Report Share Posted January 13, 2013 I am going to see what type of tint or mesh I can find for the sensor. Like you said, it will be trial and error but important enough for me to have the lights come on sooner. I am going to be adding the DRL's which one of the members sells but those don't turn on the tail lights. It will be good for the front end, but I still want visibility from the rear also in overcast/dim/cloudy conditions. Quote Link to comment Share on other sites More sharing options...
