Viperguy Posted December 23, 2012 Report Share Posted December 23, 2012 I'm going to be installing a component speaker system in the front of my '07 Edge. I noticed in the door jam there is some sort of "plug" with the rubber conduit that all the wires run through into the door. Does anyone know how to "unplug" that or is there an easy way to run the aftermarket speaker wire through there. The rubber conduit makes a big loop so I don't think it I could feed it through there like it is. Thanks Viperguy Quote Link to comment Share on other sites More sharing options...
Dingo Posted December 24, 2012 Report Share Posted December 24, 2012 Why not use the factory wires? Quote Link to comment Share on other sites More sharing options...
Viperguy Posted December 24, 2012 Author Report Share Posted December 24, 2012 I had thought about doing that but since I'm running an amp with this, I wanted to run the larger wires. I was finally able to get that plug undone with some force and just ran the wires through the empty spots in it. Quote Link to comment Share on other sites More sharing options...
Tacyon Posted December 24, 2012 Report Share Posted December 24, 2012 Viper - did you have to hog out the un-used spots .. or were you able to get them thru some how ? Quote Link to comment Share on other sites More sharing options...
Viperguy Posted December 27, 2012 Author Report Share Posted December 27, 2012 I had to drill a couple small holes in order to run the wires through the plug. Quote Link to comment Share on other sites More sharing options...
