jehill281 Posted December 10, 2012 Report Share Posted December 10, 2012 I have an 09 Edge with 95k on the clock. Recently I noticed that my reverse lights were not working. I checked the fuse, removed and replaced, put the vehicle in reverse with the park brake applied and verified that the lamps worked. That evening the lamps were not working, I replaced the fuse, verified that the lights worked, next time I was in reverse no lights. I also replaced the bulbs, same thing lamps worked until I shifted into Drive. Does anyone know if there is a reverse switch on the tranny, or any suggestions on what to look for would be appreciated Quote Link to comment Share on other sites More sharing options...
PrinzII Posted December 11, 2012 Report Share Posted December 11, 2012 When you looked at the bulbs, did you check the sockets' condition? Quote Link to comment Share on other sites More sharing options...
