69fastback Posted December 9, 2012 Report Share Posted December 9, 2012 I've done a search, and can't come up with anything. Can someone tell me where the sensor is located? Is it easily accessible? Quote Link to comment Share on other sites More sharing options...
69fastback Posted December 10, 2012 Author Report Share Posted December 10, 2012 Well, I've come up with a few answers, for those interested. The sensor itself is easy to get to, but not so simple to change. The fluid has to be drained, and the main control cover cover has to be removed from the transmission, because the wiring is internal, therefore you need to be able to access it from the inside simply to unplug the old sensor, and plug the new one in. The process calls for 2.8 hours, so it's quite a job just replace the sensor. Guess I'll get it done tomorrow. Quote Link to comment Share on other sites More sharing options...
69fastback Posted December 19, 2012 Author Report Share Posted December 19, 2012 Since this forum is so full of extremely helpful information for those who prefer to fix their vehicle themselves, rather than get raped by a mechanic, I'll add some information to this for people who may be doing a search for the same problem I had, which seems to be a somewhat common problem. The turbine/input shaft sensor is located in the front of the transmission, towards the drivers side of the vehicle. Like most speed sensors, it's a small back piece, held into the case by a single 8mm bolt. If you've changed speed sensors on other vehicles, you may be looking for something that has an electrical plug, but the trick to this sensor, is that the plug is actually inside the transmission, which makes this particular sensor a little more difficult to change. First you need to drain the trans fluid by removing the drain plug. The connector for the sensor is inside the black plastic main control cover on the front of the trans. In order to get to all the bolts on the cover, you'll need to remove the air box, which requires you to move a few lines and hoses around. It CAN be done without removing the coolant hoses, so leave them. It's fairly easy to get the cover off, but once you get in there, that's where the difficulties lie. The Chinese engineer that designed this, either had tiny fingers, or intended you to just throw the trans in the trash when it malfunctions. The electrical plug has to fished, and snaked through a very small channel, and then has to go through a hole that's the exact same size as the plug. The problem with that, is that by the time it gets back to that hole, you can't reach it with the single finger that you're able to push into the channel. In hind sight, I recommend to tie a string to the electrical plag of the sensor that you're removing, so it pulls it through when you remove the sensor, then tie the end of the string that you just pulled through onto the plug of the new sensor, to help guide it back through in the installation process. Once you get the old wire snaked out, and the new wire snaked back in, you've got it kicked. It took me 7 quarts to top the trans back off. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 19, 2012 Report Share Posted December 19, 2012 Good info! Thanks. Quote Link to comment Share on other sites More sharing options...
