Twert Posted November 27, 2012 Report Share Posted November 27, 2012 Hey everybody I just got a used 2008 Edge and the for some reason I can't get any low end to come out of the speakers and the subwoofer doesn't work even when I adjust it? Does anyone have any suggestions?? Quote Link to comment Share on other sites More sharing options...
UnderConstruction Posted December 1, 2012 Report Share Posted December 1, 2012 If its a aftermarket radio you may need a harness that connects the sub to radio. If its the stock radio you may want to make sure that sub cable is connected Quote Link to comment Share on other sites More sharing options...
Wayne B Posted February 21, 2013 Report Share Posted February 21, 2013 I have the same problem with my 08 edge and I can tell you that it is your amp that is located in the back panel on the passengers side .I took mine out played with the connection witch made it work for a while.You need to buy a new one. to look at the amp you need a # 50 torx socket to take off the seatbelt on the rear seat,then the panel will just come off with a little tug,the amp is behind the sub witch you need to undo 3 bolts ,the amp is on the back side of this chech your connection maybe you can get your's to work.Good luck a new on is around $160.00 Quote Link to comment Share on other sites More sharing options...
