LATEST AND GREATEST SYNC UPDATE
Hello,
I read someplace about a new software release to update MFT nav systems.
There is a TSB out #12-11-1 that relates to 2011-2013 Edges and Explorers.
My Ford dealer has not contacted me about this, so I learned about it from SMR.
According to the TSB, the upgrade may need a new SD card, version A4.
My question is;
1- Has Ford shipped or planning to ship the software upgrade thumbdrive WITH the SD card?
2- If it needs to be done at the dealer, will they charge you for the new A4 SD card?
3- If you had it installed. Asside from reinstalling addresses and reparing phone, does it run better?
Thanks much all.
According to what I've seen on other forums:
1 - no but you can download the software yourself using the link in the TSB. I'll try to post it if I can find it. You'd still have to go to the dealer for a new card I presume.
2 - no
3 - yes - response is reported to be much better and much faster with improved voice recognition
Hi akirby,
I spoke to the svc mgr. at the Ford dealer. They would need to hold the car for the day, and will not hand over the SD card b/c they fear the customer will "mess things up".
So it looks like I'll have to take it in.
I did download the software upgrade to a thumb drive, but to do the complete job, you need the card too, so i"m stuck.
Another question, SMR has another download for checking your current software level.
I followed the instructions to download, put the drive into the port in the car, started it, drive light was flashing, waited a few minutes, then removed the drive.
Version info should be on the drive, yes?
I go back to the SMR site, but did not find instructions on how to upload and find out what I have.
What did I miss?
