Speaker replacement 13'
Removal and Installation
MKX Vehicles
1. Remove the front door switch panel.
Disconnect the electrical connectors.
Edge Vehicles
2. Remove the front door inside handle bezel.
All Vehicles
3. Remove the window control switch..
4. Remove the 2 front door trim panel bolts.
5. Remove the 3 front door trim panel screws.
6. Disengage the bottom of the door trim panel from the door.
Pull outward on the trim panel to disengage the push pins and retaining clip from the door.
7. Lift the top of the door trim panel edge upward and out of the belt line moulding.
8. Lift the door trim panel up and off of the lock rod.
9. Remove the front door trim panel.
