DunePearlEdge Posted October 27, 2012 Report Share Posted October 27, 2012 My Mother-in-law is planning to purchase a used Edge SE. She likes the SE because the manual seats go higher than the electric ones. She likes the look of the fog lamps on my SEL. Has anyone added the stock fog lamps to an SE? I found the fog lamp bezels online: http://www.ebay.com/itm/New-Replacement-Chrome-Fog-Lamp-Bezel-Bumper-Insert-LH-FOR-2007-10-FORD-EDGE-/370618765708?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AFord%7CModel%3AEdge&hash=item564a99918c&vxp=mtr There are also the fog lamps themselves and if I dig enough I bet I could find the OEM head lamp dash switch that pulls out for fog lamps. If anyone has attempted this, were you able to plug into the stock wiring harness or did you have to run separate wires? I know sometimes the wiring harness has connections for equipment that is not installed e.g., my Edge has a connection for back-up sensors although my vehicle isn't equipped with them. Any advice is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted October 27, 2012 Report Share Posted October 27, 2012 There is no wiring at all for the fog lamps. You can splice the wires to the low beams and run it off of those or others have gotten smaller LED fog lights and put them through the grille and wired them other ways. There is another post on here about this same thing, look it up. Good luck Quote Link to comment Share on other sites More sharing options...
EdgeRacer Posted October 28, 2012 Report Share Posted October 28, 2012 I actually have been wondering the same thing! Since I bought an SE and regret it! Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 29, 2012 Report Share Posted October 29, 2012 I had explored this with my 2008 Edge SE and found that you need the following: New Light Switch Bezels Foglight Housings Foglight Bulbs Then, you have to wire it to the stock electrical system, Quote Link to comment Share on other sites More sharing options...
EdgeRacer Posted October 29, 2012 Report Share Posted October 29, 2012 Where is the switch in the SEL for fog lights? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 29, 2012 Report Share Posted October 29, 2012 It is the headlamp switch. You pull it out towards you to activate the fog lights and push back in to turn them back off. Quote Link to comment Share on other sites More sharing options...
EdgeRacer Posted October 30, 2012 Report Share Posted October 30, 2012 OK so ill have to look and see if i can find this switch somewhere on ebay. I want it to look as stock as possible. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted November 1, 2012 Report Share Posted November 1, 2012 ...or check with Benny from Levittown Ford to get the stock switch cheap. Quote Link to comment Share on other sites More sharing options...
EdgeRacer Posted November 2, 2012 Report Share Posted November 2, 2012 WHO???? Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted November 2, 2012 Report Share Posted November 2, 2012 WHO???? Post your question or needs under the Levittown Ford Super Center category under "Ford Edge Sponsor Forums" and Benny will respond with details 1 Quote Link to comment Share on other sites More sharing options...
