Looking to remove my factory side rails
Hi
I have a 2012 Edge and am looking to remove my factory installed side rails. Does anybody know what the part number is to for the plastic insert to replace my side rails. I am planning on keeping the side rails so I am not looking to trade anyone.
Thanks Andy
Have you checked with your Ford parts department for the number?
I added the Ford side rails after I took delivery of my 2012 last November. Part of the change required new plastic mounting clips for the front and rear of each side. The middle clip didn't change. You should figure out if the clips used for the rails will still work with the non-rail plastic insert. I suspect they may not, otherwise it would be the same clip whether you had the rails or not. If you need to change clips, you will also have to fill in and seal an empty bolt hole under each of the clips.
