precious Posted October 24, 2012 Report Share Posted October 24, 2012 I got in precious this morning to make a run to town to find that she was sick. She was running rough so, I got to the end of the street and turned around to head back to the garage and the chk engine light came on. My husband had it checked and it coded a misfire on cylinder 4. The car has 80k+ and the original plugs look good. Wondering if it could be the coil and if so, how can you check to see if the coil is bad before I make a $80 mistake. Thanks Quote Link to comment Share on other sites More sharing options...
frozennuts Posted October 24, 2012 Report Share Posted October 24, 2012 I got in precious this morning to make a run to town to find that she was sick. She was running rough so, I got to the end of the street and turned around to head back to the garage and the chk engine light came on. My husband had it checked and it coded a misfire on cylinder 4. The car has 80k+ and the original plugs look good. Wondering if it could be the coil and if so, how can you check to see if the coil is bad before I make a $80 mistake. Thanks Swap the coil from number 4 with another and see if the problem moves to the other cylinder. If it does then its a good chance that your coil is the problem, if it does not, then check the coil connector. Quote Link to comment Share on other sites More sharing options...
