2009 Lincoln MKX Towing
My 2013 Edge Limited came with the towing package from the factory. It says it includes the Class II hitch, trailer sway control (turned on or off through the driver's information center), larger radiator, upgraded cooling fans, wiring harness w/4 pin connector, and a 3500 lb towing maximum capacity. It says nothing about a transmission cooler upgrade or addition. Perhaps the larger radiator is the upgrade for the transmission cooling?
You have a larger engine so I don't know if anything changed for the 3.7 MKX. I don't see a towing option for the Edge Sport (3.7 engine) so I can't tell if anything else would be different on yours.
Have you checked the Lincoln website to see if anything is listed there? Here is a quick link where they talk about the tow/sway option. You might have to dig deeper to see what other items are included.
http://www.lincoln.com/crossovers/mkx/features/#page=Feature7
