Twister Posted October 17, 2012 Report Share Posted October 17, 2012 Does anyone know if there's a way route the engine block heater cord, so that the hood need not be opened to connect? Currently it's clipped to the top of the rad and hangs down behind the radiator fan. Quote Link to comment Share on other sites More sharing options...
frozennuts Posted October 19, 2012 Report Share Posted October 19, 2012 Does anyone know if there's a way route the engine block heater cord, so that the hood need not be opened to connect? Currently it's clipped to the top of the rad and hangs down behind the radiator fan. I located the cable around the side of the rad and located the plug between the gaps of the chrome grill (just out of sight) but easy to plug in without lifting the hood. Alternatively, take a look at what is available in Europe http://www.defa.com/en/fp/main/ Ok, voltage is different but connector will still work. Quote Link to comment Share on other sites More sharing options...
Twister Posted October 19, 2012 Author Report Share Posted October 19, 2012 I located the cable around the side of the rad and located the plug between the gaps of the chrome grill (just out of sight) but easy to plug in without lifting the hood. Alternatively, take a look at what is available in Europe http://www.defa.com/en/fp/main/ Ok, voltage is different but connector will still work. Thanks for the info. I made up a short extension cord and did the same thing as yourself. Quote Link to comment Share on other sites More sharing options...
