Calibre Posted October 9, 2012 Report Share Posted October 9, 2012 Anyone know the correct HID bulb for 2013 Edge. The factory bulb is 9012, but some suppliers say 9006 works. Anyone know the real scoop??? Thanks Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 9, 2012 Report Share Posted October 9, 2012 That is correct on both counts. Some vendors use 9006/9012 interchangably. Quote Link to comment Share on other sites More sharing options...
Calibre Posted October 9, 2012 Author Report Share Posted October 9, 2012 Thanks for the info...... I noticed you have 5k LED puddle lamps. Are they from Brightlights.com.Kansis? Quote Link to comment Share on other sites More sharing options...
candurin Posted October 9, 2012 Report Share Posted October 9, 2012 9006 will work. One of the tabs (out of three) will be a little bit larger, but with some careful insertion (yeah, I laughed too) you'll get it in (laughed again). Depending on the manufacturer, some are easier than others. Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 9, 2012 Report Share Posted October 9, 2012 Thanks for the info...... I noticed you have 5k LED puddle lamps. Are they from Brightlights.com.Kansis? Yep. Got them from KC300C. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted October 9, 2012 Report Share Posted October 9, 2012 I used a 9005 in my 2011. Works perfect, Did the bulb change in subsequent years? Quote Link to comment Share on other sites More sharing options...
Calibre Posted October 10, 2012 Author Report Share Posted October 10, 2012 I'm not sure if there was a change. I've been told the bulb that works is a 9006. The tabs on the 9006 look different and much smaller than the factory 9012. I received some great advice on the forum to use the 9006 and shape one of the tabs to make it fit. Sounds like good advice since a 9012 is non existent. Quote Link to comment Share on other sites More sharing options...
candurin Posted October 10, 2012 Report Share Posted October 10, 2012 Again, depends on mfg. ddm needed no alteration on the 9006 and on my TRS HIDs I needed to Dremel one tab a bit thinner. Took 40 seconds. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted October 10, 2012 Report Share Posted October 10, 2012 You know, come to think of it...I was told to use a 9006 in our 2011 Explorer, and had a real bitch of a time lining up the bulbs... Yet on my Edge I used a 9005 and had no problems. Im going to compare the two when we get the Ex back and see if it makes a difference. Ill report back once thats done. Quote Link to comment Share on other sites More sharing options...
