Circle3 Posted October 8, 2012 Report Share Posted October 8, 2012 (edited) I would like to rewire the vertical LED light pipes on the front bumper for DRL. I have tried the dealer route of programming the BCM to run DRL as Ford does with Canadian cars. This cannot be done in the US. Reasons were either hard coded or Canadian software not allowed in the US. I tried two dealers, got the same story. I do not need a light conversion kit as I have HID. How can the vertical LED strip be rewired to be on all the time? Or better yet the amber turn signals as DRL. UPDATE: I think I found my solution: http://www.daytimebrightlites.com/ I see there are detail posts on how to remove the LED pipes from the front bumper and soften them up in the oven to take apart then epoxy back together with various LED DRL's. One mistake and you have a mess. The link above looks like a plug and play solution. I am going to give this vendor a try. Edited October 9, 2012 by Circle3 1 Quote Link to comment Share on other sites More sharing options...
kc300c Posted October 10, 2012 Report Share Posted October 10, 2012 Hi Circle3, You may have already sent me an email, but if not my Vertical LED Running Lights are a plug and play system. Easily pop out the stock lights and pop mine in. There is no wire cutting or modifications to the electrical system of your Edge. I have tons of photos and videos showing our different DRL options. You can see exactly what's involved with installing the lights. It's very easy and shouldn't take much more than 30 - 45 minutes, even for a novas. Quote Link to comment Share on other sites More sharing options...
mtbalser Posted October 11, 2012 Report Share Posted October 11, 2012 Can't go wrong with DLBLs. Lights are awsome! Quote Link to comment Share on other sites More sharing options...
kc300c Posted November 21, 2012 Report Share Posted November 21, 2012 (edited) Thanks for the kind words about my lghts Mike Edited November 21, 2012 by kc300c Quote Link to comment Share on other sites More sharing options...
