Spotlight Bulb Replacement
Twister
I copied this from our 08 MKX owners manual.
The bulb is an H11.
I down loaded the PDF at.
https://owner.ford.c.../OwnerGuidePage
Replacing fog lamp bulbs
1. Make sure the fog lamp switch is
in the OFF position.
2. From underneath the vehicle,
remove the splash shield and rotate
the harness/bulb assembly
counterclockwise, to remove from
the fog lamp.
3. Carefully disconnect the bulb
from the harness assembly via the two snap clips.
Install the new bulb in reverse order.
ab
The bulb is an H11.
the fog lamp.
ab
Removing the splash shield is the pits. Looks like that's the only way.
Thanks all.
