cmillz1331 Posted October 3, 2012 Report Share Posted October 3, 2012 So I noticed this noise when turning dating back to last fall actually. A lady backed into my front passenger side wheel in a parking lot and didn't seem to do any damage. Later while driving I noticed a loud clunk sound when turning, both ways! It usually happens when I have to make sharp or quick turns where the wheel is turned fairly far. I thought maybe the problem would go away but it hasn't. It hasn't gotten any worse but hasn't gotten better either. When I had it up at a Ford dealer for some other work, they said they couldn't replicate the problem....I drove it home and it happened at least a couple times. The problem helper on NTB.com said it could be any of these things: 1) Loose/worn tie rod ends 2) Worn or dry ball joints 3) Axle assembly failure... I have no knowledge or experience with this area so can anyone help or has anyone had this problem? I would greatly appreciate it. I need new tires before winter so I'll ask them to check it out but I don't want to get ripped off either.....Thanks! Quote Link to comment Share on other sites More sharing options...
c_bova Posted October 3, 2012 Report Share Posted October 3, 2012 I'd check end links as well. Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted October 3, 2012 Author Report Share Posted October 3, 2012 On 10/3/2012 at 5:16 PM, c_bova said: I'd check end links as well. Okay ill add that to the list. thanks Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted November 8, 2012 Author Report Share Posted November 8, 2012 So the sound has greatly decreased since I recently had an alignment last weekend. I have only heard it a few times compared to multiple times a day like before. But it still occurs....the guy said my alignment was really far off to the right so I thought maybe something was just rubbing but it's still happening while my car doesn't pull or anything anymore....The problem has been helped but not completely fixed Quote Link to comment Share on other sites More sharing options...
UnfocusedEdge Posted November 8, 2012 Report Share Posted November 8, 2012 (edited) Might have damaged the cv joint. Hard to tell just by looking at it. Edited November 8, 2012 by UnfocusedEdge Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted November 8, 2012 Author Report Share Posted November 8, 2012 On 11/8/2012 at 1:31 AM, UnfocusedEdge said: Might have damaged the cv joint. Hard to tell just by looking at it. If that is what happened, any problems if I don't get it fixed right now? Quote Link to comment Share on other sites More sharing options...
UnfocusedEdge Posted November 8, 2012 Report Share Posted November 8, 2012 I found advise getting it checked out. I had one fail on my focus and could move the car on its own power. Not sure what would happen with AWD. Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted November 8, 2012 Author Report Share Posted November 8, 2012 On 11/8/2012 at 4:15 PM, UnfocusedEdge said: I found advise getting it checked out. I had one fail on my focus and could move the car on its own power. Not sure what would happen with AWD. Okay thanks. Quote Link to comment Share on other sites More sharing options...
fixitall123 Posted December 28, 2013 Report Share Posted December 28, 2013 Just cured my klunk. It was the ball joint that was loose. Quote Link to comment Share on other sites More sharing options...
