balligood998 Posted September 10, 2012 Report Share Posted September 10, 2012 Will using AMSOIL after my first oil change void my powertrain warranty on my 2013SE. I have used there oil for several years and I run it in my F 150. But just don't know how about Fords warranty, not clear. Quote Link to comment Share on other sites More sharing options...
Feirstein Posted September 10, 2012 Report Share Posted September 10, 2012 Ford recommends an SN quality 5W-20 for the latest Edge. The use of Amsoil will not void the warranty. I use Mobil 1 Extended Performance 5W-20 which I know meets Fords requirements. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 10, 2012 Report Share Posted September 10, 2012 If it meets the Ford spec it's perfectly fine but I'm not sure if it does. The spec is in your owner's manual. If you don't use the proper spec oil and you have a lubrication related failure then Ford may not cover it but there is no such thing as "voiding the warranty" outright. Quote Link to comment Share on other sites More sharing options...
