MyFord Touch V3.2
for those that want the new update but don't want to go to their dealer: http://www.syncmyrid....atepackage.exe
extract to usb drive that is at least 2GB. it wasn't available from syncmyride.com
install is the same as 3.0.2
new version is 3.2
"Customers with the above referenced vehicles may experience the following concerns with their MyFord
Touch / MyLincoln Touch technology. The MyFord Touch / MyLincoln Touch Software Release v3.2 will address the following conditions and provide all previous performance upgrade enhancements:
*Missing radio preset text
*Radio stays on key off after opening the door
*Voice recognition inoperative - pressing the push to talk button on the steering wheel does not initiate audio prompt "please say a command"; only Listening icon is displayed
*Sirius travel link fuel prices show as unsubscribed when it is subscribed"
I believe someone said it will put the outside temp back on the 8" lcd.
also after looking through the install file it will tell you if yours is compatible or not.
; Microsoft Windows Automotive
; USB Installation Directive File
; 3.2 (12156) Update from:
; 10308,10337,11038,11063,11081,11134
; 11339,11346,12023,12094,12131
; Other versions not supported
; autoinstall.lst NA
; Supported by this update
[sYNCGen2_4.22.10308_PRODUCT]
Item1 = BT4T-14D546-ED.cab
Open1 = SyncMyRide\BT4T-14D546-ED.cab
Item2 = DA5T-14D546-VB.cab
Open2 = SyncMyRide\DA5T-14D546-VB.cab
Item3 = DA5T-14D546-XB.cab
Open3 = SyncMyRide\DA5T-14D546-XB.cab
Item4 = BT4T-14D546-FA.cab
Open4 = SyncMyRide\BT4T-14D546-FA.cab
Item5 = DA5T-14D546-HA.cab
Open5 = SyncMyRide\DA5T-14D546-HA.cab
Item6 = DA5T-14D546-JB.cab
Open6 = SyncMyRide\DA5T-14D546-JB.cab
Item7 = DM5T-14D621-AB.cab
Open7 = SyncMyRide\DM5T-14D621-AB.cab
Item8 = DA5T-14F497-AF.zip
Open8 = SyncMyRide\DA5T-14F497-AF.zip
Item9 = DA5T-14D546-AF.zip
Open9 = SyncMyRide\DA5T-14D546-AF.zip
Item10 = DA5T-14F657-AG.zip
Open10 = SyncMyRide\DA5T-14F657-AG.zip
Item11 = DA5T-14D545-ASA.zip
Open11 = SyncMyRide\DA5T-14D545-ASA.zip
Item12 = DA5T-14D546-KA.cab
Open12 = SyncMyRide\DA5T-14D546-KA.cab
Item13 = BT4T-14D546-ED.cab
Open13 = SyncMyRide\BT4T-14D546-ED.cab
Item14 = DA5T-14D546-XB.cab
Open14 = SyncMyRide\DA5T-14D546-XB.cab
Item15 = DA5T-14D546-LB.cab
Open15 = SyncMyRide\DA5T-14D546-LB.cab
Options = AutoInstall
[sYNCGen2_4.22.10337_PRODUCT]
Item11 = DA5T-14D545-ATA.zip
Open11 = SyncMyRide\DA5T-14D545-ATA.zip
[sYNCGen2_4.23.11038_PRODUCT]
Item11 = DA5T-14D545-AUA.zip
Open11 = SyncMyRide\DA5T-14D545-AUA.zip
[sYNCGen2_4.23.11063_PRODUCT]
Item11 = DA5T-14D545-AVA.zip
Open11 = SyncMyRide\DA5T-14D545-AVA.zip
[sYNCGen2_4.23.11081_PRODUCT]
Item11 = DA5T-14D545-AXA.zip
Open11 = SyncMyRide\DA5T-14D545-AXA.zip
[sYNCGen2_4.23.11134_PRODUCT]
Item11 = DA5T-14D545-AYA.zip
Open11 = SyncMyRide\DA5T-14D545-AYA.zip
[sYNCGen2_4.26.11339_PRODUCT]
Item11 = DA5T-14D545-BAA.zip
Open11 = SyncMyRide\DA5T-14D545-BAA.zip
[sYNCGen2_4.26.11346_PRODUCT]
Item11 = DA5T-14D545-BBA.zip
Open11 = SyncMyRide\DA5T-14D545-BBA.zip
[sYNCGen2_4.26.12023_PRODUCT]
Item11 = DA5T-14D545-BCA.zip
Open11 = SyncMyRide\DA5T-14D545-BCA.zip
[sYNCGen2_4.28.12094_PRODUCT]
Item11 = DA5T-14D545-BDA.zip
Open11 = SyncMyRide\DA5T-14D545-BDA.zip
[sYNCGen2_4.28.12131_PRODUCT]
Item11 = DA5T-14D545-BEA.zip
Open11 = SyncMyRide\DA5T-14D545-BEA.zip
; The version we are updating to
[sYNCGen2_4.28.12156_PRODUCT]
Item1 = DA5T-14D546-KA.cab
Open1 = SyncMyRide\DA5T-14D546-KA.cab
Item2 = BT4T-14D546-ED.cab
Open2 = SyncMyRide\BT4T-14D546-ED.cab
Item3 = DA5T-14D546-RA.cab
Open3 = SyncMyRide\DA5T-14D546-RA.cab
; Not supported by this update - go to dealer
[sYNCGen2_4.21.10212]
Item2 = DA5T-14D546-NA.cab
Open2 = SyncMyRide\DA5T-14D546-NA.cab
[sYNCGen2_4.23.10353]
[sYNCGen2_4.23.11015]
[sYNCGen2_4.23.11069]
[sYNCGen2_4.26.11304]
; All other cases not previously listed
[sYNCGen2_All]
Item2 = DA5T-14D546-PA.cab
Open2 = SyncMyRide\DA5T-14D546-PA.cab
I'm reading the focus forum, http://www.focusfana...t=296653&page=5, and some of them are reporting that the climate function/feature of MFT no longer works.
Not sure if this is specific to the focus or if we would run into the same issues with our Edges.
On a good note, temp display on center of MFT screen is back (as reported in the forum I linked)...
Edited by candurin
I did the install. Temp is back along with a choice to show it there or not. Everything else seems to work just fine, have not had a ton of time to test.
Of course all my presets, phone etc. had to be setup again... no big deal.
Where do you find the info on choosing it or not? I have it but couldn't find it in the system settings
Ps. My presets were kept with the exception of my Nav favorites and I had to repair the phone
Edited by tpm419419
Pulled the trigger and updated with no issues (took about 40 minutes or so). The only things that were reset were my Sirius presets and I had to reconnect my iPhone.
Here's a few screenshots:
1. Upon completion of the installation, you'll get a notice that you're update has been succesful:
2. Installation Complete! - Showing the temperature is back on the home screen:
3. Here's where you turn on and off the temp display (under settings > Clock):
4. Here's the version # according to MFT:
5. Succesful install reported on SyncMyRide:
Edited by candurin
WOW...I feel dumb... I obviously don't know know how to install this file to the root of the USB, because MFT isn't finding it, and its the only thing on a Kingston 4GB USB drive... What am I doing wrong? Every other MFT update has gone on without a hitch.
I have been using a Kingston 8GB USB for the last two weeks in my 2013 Edge for some music I downloaded to it. The MFT sometimes finds the Kingston, and some times does not. I can get it to start by using voice commands and it will be OK for a day or two. Perhaps you should try a different USB drive, or a voice command to find the Kingston? I have to try downloading onto a different USB to see if it helps my situation.
By the way I would LOVE to have the temperature displayed in the center home screen instead of just in the little window to the right of the steering wheel in the dash. I guess this was one of the "upgrades" to the 2013 version. I'll keep watching to see if there is an update sometime to allow that.
