Door Sill Plates
Has anyone switched out the non-lighted door sill plates for the lighted ones? I was wondering if there is a plug in tucked away under the plastic piece that can be pulled off. The instructions say dealer installation recommended but I've never heeded that BS caution before.
Anyone done this changeover?
Chris
  • 4 weeks later...
I installed non-lighted Momo brand aluminum sill plates on all our vehicles . They for some reason have corroded on the Edge . Moisture must sit on them in our climate . I'd think that if his sill plates have lighting the wiring will have to have a hole in panel that water could enter if it isn't sealed well . The only other way possible is a pigtail that runs under the inner sill plastic panel and weatherstrip to where it could be routed along the rocker and inner kick panel into the dash harness .
