Where to put in SD-card in 2008 Edge?
Hi!
Just bought a 2008 Edge and stumbled across inserting a Navigation SD-card! The MyFord Touch Navigation system hasn't got any SD-card slot, and my USB drive just recognizes audio files (I tried it with an SD-card reader).
Anyone who has got an idea how I can make the SD-card run?
Thanks!
Stephan
Navteq is the supplier of map DVD's for Ford. You should check out their website and see if there is a European DVD you can purchase or find on eBay.
Otherwise, your only other option is to buy an aftermarket navigation system. There are many double DIN units that would fit, check out www.crutchfield.com
Edited by clem151
