Sandra Sutton Posted August 23, 2012 Report Share Posted August 23, 2012 Traveling and away from home in our towed 2007 Ford edge yesterday driving car to eat engine got hot noticed fan did not come on. when driving down the road by turning air conditioner off air cools motor. in town car gets hot at red lights. day 2 noticed fan did is still not coming on same thing on car getting hot. Checked anti freeze levels. Looked in guide book that came with car. Cannot find where a relay switch might be. looking for diagram and possible solutions Quote Link to comment Share on other sites More sharing options...
frozennuts Posted August 24, 2012 Report Share Posted August 24, 2012 If temperature sender has failed, the fans will run all the time. Turning the A/C on max with a cold engine will turn the fans on. Hopefully its a fuse or relay or the connector to the fans (you have two fans, yes?) if yes, can't believe they have both failed. Fuses and relays for the cooling fan are in the fuse box under the hood next to the battery. The fuses are F5 and F2 (40A & 60A) and the relay is relay 2 located between fuse 1 & 2 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted September 7, 2012 Report Share Posted September 7, 2012 I had a similar issue with our 2008 but it actually turned out to be the fan itself that was going bad. Unfortunately, you cannot replace one fan as it is 2 fans in a single unit. My wallet took a $600 hit from that repair. Quote Link to comment Share on other sites More sharing options...
