Ampilifier Location + changer problem
Hey guys
I just bought EDGE 2009 limited great car!
but I have some little probs.
1. where is the location of the Amp? I want to use an aftermarket amp
2. can i add an aftermarket amp with the same wires of the factory amp?
3. is there any guide showing me how to remove the subwoofer plastic ?
4. I have problem with the six cds charger i just cant insert cds , i already searched about this problem and they tell me there to insert knife and lift up but i cant even insert in the knife. i think somehow the charger closed and locked ;\
thanks
The amp for the sub is right next to the sub behind the panel. The new amp you get will most likely need a larger power and ground cable. So most likely you will need all new wiring. Go to this link http://www.jlaudio.com/car-audio-stealthbox-ford-edge and then go to support towards the bottom and download the manual, it shows you in detail how to remove the panel.
