scottty6 Posted August 6, 2012 Report Share Posted August 6, 2012 Has anyone had any experinence with the Edge down-shifting while going downhill (coasting). My Edge would shift into 4th while I was coasting down a 6% grade. I can only assume the car was thinking for me and trying to use engine compression to slow the car. Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 6, 2012 Report Share Posted August 6, 2012 Good assumption. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 7, 2012 Report Share Posted August 7, 2012 Very good assumption that is also documented in the owner's manual. Quote Link to comment Share on other sites More sharing options...
RJG Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) I try to avoid using my transmission like that. That's what brakes are for. And brakes are relatively cheap to fix when they wear out. Transmission not so cheap. Don't understand why Ford would program that in. Maybe when towing, brakes need some help. Maybe 50-60 years ago, when car brakes didn't work well, you used the transmission to help you slow down. Not now. Edited August 7, 2012 by RJG Quote Link to comment Share on other sites More sharing options...
ladybird4 Posted August 7, 2012 Report Share Posted August 7, 2012 Towing or not i would never use my brakes when going downhill on a log stretch of road. People that do this are the ones i drive behind and smell there brakes all the way down the mountain. Sorry if i offend you but i have never heard of anyone being advised to use there breaks instead of downshifting. Quote Link to comment Share on other sites More sharing options...
c_bova Posted August 7, 2012 Report Share Posted August 7, 2012 50-60 years ago cars transmissions weren't built like they are today, I'm pretty sure they can take it. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 7, 2012 Report Share Posted August 7, 2012 I try to avoid using my transmission like that. That's what brakes are for. And brakes are relatively cheap to fix when they wear out. Transmission not so cheap. Don't understand why Ford would program that in. Maybe when towing, brakes need some help. Maybe 50-60 years ago, when car brakes didn't work well, you used the transmission to help you slow down. Not now. Using a lower gear when going downhill will not hurt the transmission at all. And riding the brakes down a long hill generates a lot of heat which is not good and if used long enough can actually cause loss of braking which is why they advise you to downshift in the mountains when going downhill. Quote Link to comment Share on other sites More sharing options...
Waldo Posted August 7, 2012 Report Share Posted August 7, 2012 I try to avoid using my transmission like that. That's what brakes are for. And brakes are relatively cheap to fix when they wear out. Transmission not so cheap. Don't understand why Ford would program that in. Maybe when towing, brakes need some help. Maybe 50-60 years ago, when car brakes didn't work well, you used the transmission to help you slow down. Not now. How does the transmission get more wear in 4th gear than 6th? Quote Link to comment Share on other sites More sharing options...
timf Posted August 7, 2012 Report Share Posted August 7, 2012 I've found the Edge to be very effective at using engine braking going downhill when cruise control is active. It doesn't seem to do this as much or at all when cruise is turned off. Quote Link to comment Share on other sites More sharing options...
CARR142 Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) I use this feature to manually reduce the speed by lowering the set speed of cruise control to slow the vehicle down before I use the brakes, when possible. although, The active cruise control instructions states that "the brakes are applied to reduce vehicle speed" Edited August 9, 2012 by CARR142 Quote Link to comment Share on other sites More sharing options...
RJG Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) I live in Florida. No need for trans braking. But understand your points. Still think using transmission for braking mostly old school. Realize there are exceptions. I would probably lock out O/D coming off a Rocky Mtn. Edited August 7, 2012 by RJG Quote Link to comment Share on other sites More sharing options...
akirby Posted August 8, 2012 Report Share Posted August 8, 2012 If the cruise is set it will downshift to keep the speed at the set point. Without cruise on i don't think it will downshift when going downhill unless you touch the brakes. Quote Link to comment Share on other sites More sharing options...
scottty6 Posted August 9, 2012 Author Report Share Posted August 9, 2012 Thanks for all the good info. I did find in the manual after posting to the forum. I guess I just have to get used to the car making descisions for me. I'm used to the "old school" transmissions. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 22, 2012 Report Share Posted August 22, 2012 and will cost a hell of a lot less to fix if it breaks than totaling your car because the brakes wouldn't perform due to brake fade. I don't have a comment - I just wanted to congratulate you for the proper use of "break" and "brake" in the same post. 3 Quote Link to comment Share on other sites More sharing options...
akirby Posted August 22, 2012 Report Share Posted August 22, 2012 Very good akirby! Thank you for noticing. I have to admit sometimes having troubles using the two words correctly in the same sentence. :whew: Kind of like a tongue-twister in text form. It's my #1 pet peeve - using the wrong word. "break" instead of "brake" - it's not a typo, it's the WRONG word. My new favorite pet peeve is "would of" instead of "would've" or "would have". Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted August 22, 2012 Report Share Posted August 22, 2012 please, my wife is a teacher, and she is always correcting my grammer, she could give me a break (or is that brake) already ! Quote Link to comment Share on other sites More sharing options...
akirby Posted August 23, 2012 Report Share Posted August 23, 2012 please, my wife is a teacher, and she is always correcting my grammer, she could give me a break (or is that brake) already ! Grammer? Quote Link to comment Share on other sites More sharing options...
richy Posted August 23, 2012 Report Share Posted August 23, 2012 Grammer? LMFAO, Poor Joe!! Quote Link to comment Share on other sites More sharing options...
RJG Posted August 23, 2012 Report Share Posted August 23, 2012 My point above is.....when I first started driving in late 50's I was taught to use the gears to slow down and not bakes....mainly because brakes were not so good then. And transmissions were mostly manual. Now we have superb brakes in most cars, which are still relatively cheap to fix when they wear. Transmissions are very expensive to fix. So I don't see the point in down shifting every time you go off an off ramp or just want to slow down. Most experts agree with this. And sure.....if coming off a long steep hill or mountain, it's still smart to control speed with trans...agree. It won't hurt anything. Just don't see point in using our transmissions like you are a road racer or something. Quote Link to comment Share on other sites More sharing options...
Waldo Posted August 23, 2012 Report Share Posted August 23, 2012 I don't think anyone was talking about downshifting to come to a stop from freeway speed. We're talking about how the "Experts" at Ford have decided that downshifting to maintain speed on a hill is a good thing, which you now seem to agree with. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 23, 2012 Report Share Posted August 23, 2012 So I don't see the point in down shifting every time you go off an off ramp or just want to slow down. Most experts agree with this. When does a Ford vehicle downshift when you slow down or are on an off ramp? Quote Link to comment Share on other sites More sharing options...
RJG Posted August 23, 2012 Report Share Posted August 23, 2012 When does a Ford vehicle downshift when you slow down or are on an off ramp? I admit to over reacting to original post. It comes from some posts I have seen on here about how the M position on our shifter with + and - buttons can be used like you're driving a manual trans for down shifting everytime time you want to slow down. My reaction was that's a little over use of the feature. So sorry....next time I'll read and study the post a little better. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 23, 2012 Report Share Posted August 23, 2012 I admit to over reacting to original post. It comes from some posts I have seen on here about how the M position on our shifter with + and - buttons can be used like you're driving a manual trans for down shifting everytime time you want to slow down. My reaction was that's a little over use of the feature. So sorry....next time I'll read and study the post a little better. That is overkill and not at all necessary, but I'm sure there are a few folks who do it just for fun. As stated though it will only do it automatically when you have cruise control activated and it's used to keep the vehicle at the set speed going downhill or if you're going downhill and you tap the brakes - it assumes you want to slow down and will downshift to assist. Quote Link to comment Share on other sites More sharing options...
blankster Posted August 27, 2012 Report Share Posted August 27, 2012 There is a feature in the vehicle to delay the charging of the battery via the alternator to when the vehicle is "coasting". That might be what you feel. I noticed the same on mine and thought there was a trans problem but I was directed to an article regarding this feature. It is meant to same fuel and reduce load on the engine. Quote Link to comment Share on other sites More sharing options...
