wlepse Posted August 2, 2012 Report Share Posted August 2, 2012 I keep thinking about picking up one of those bluetooth OBD2 devices. I currently have a serial cable and software on a laptop to communicate with my older Audi but since the car is getting on in mileage I am expecting to get more frequent CEL and thought it would be nice to be able to have a device ready to go in the car. But from what I read these devices seem to have spotty reliability and often don't work with older VAG products. But since they were cheap enough I thought about giving it a shot figuring it would work for the Edge. But as I kept reading reviews it appears as if many Ford's don't work well with these. So I was wondering if anyone here has used one, particularly on the Edge and what your thoughts were. For those that don't know what I am talking about: http://www.amazon.com/Elandpower-Bluetooth-Scanner-OBDII-Diagnostic/dp/B004B7YXOM/ref=sr_1_2?ie=UTF8&qid=1343935493&sr=8-2&keywords=bluetooth+odb2 This with the Torque application on your android allows you to communicate with the vehicle and get all sorts of info...though what vehicles it works with may be questionable. Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 2, 2012 Report Share Posted August 2, 2012 I bought one about 2 months ago when they were on sale. Haven't used it yet. I'll test it out shortly. Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 2, 2012 Report Share Posted August 2, 2012 Just played with it. Works fine on the galaxy s3. Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 3, 2012 Author Report Share Posted August 3, 2012 You were able to communicate with the Edge? The BT OBD2 device you have, is it the one I linked to on Amazon or is the blue bodied one? Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 3, 2012 Report Share Posted August 3, 2012 (edited) http://www.amazon.com/gp/aw/d/B006T0M7Q0/ref=redir_mdp_mobile?ref_=pe_175190_21431760_M2T1_SC_3p_dp_1 Here's proof that it works... Edited August 3, 2012 by Dingo Quote Link to comment Share on other sites More sharing options...
autom8r Posted August 3, 2012 Report Share Posted August 3, 2012 The BT OBD adapter device works great. I use a program called TORQUE OBD reader. It's a free android app. I run it on my Motorola Razor phone and on my Motorola Xoom tablet. I threw a code this morning on my locking gas cap. Using the TORQUE app, I was able to read and clear the code. The data can also be stored and exported. Have fun. Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 3, 2012 Author Report Share Posted August 3, 2012 Thanks Dingo...probably place the order this weekend to give it a shot. Quote Link to comment Share on other sites More sharing options...
Tacyon Posted August 4, 2012 Report Share Posted August 4, 2012 (edited) I was looking into this as well with the track feature. The torque site has a comparison of the OBD BT dongles. Seems as not all are created equal. http://torque-bhp.co...etooth_Adapters My Garmin GPS has a app that I could have purchased for it and used a BT dongle - after doing my research, I'm glad I didn't. "however the adapter proved to be too slow to be of any use." This bad boy seems to be the shiznit - http://www.scantool.net/obdlink-mx.html but kind of rich for a toy on a non-performance vehicle. Edited August 4, 2012 by Tacyon Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 4, 2012 Author Report Share Posted August 4, 2012 Thanks for that link to the Torque wiki...not sure I saw that page but that was similar info to other things I read indicating that some units are hit and miss. I ended up ordering from Amazon just because of the return policy...hoping I don't need to use it. Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 7, 2012 Author Report Share Posted August 7, 2012 Well I got mine yesterday and it did see the ECU on the Edge and on the Audi which is good but really haven't had much time to play with it. The little bit I did play with makes me question some of the gauges but I will double check with my laptop just to verify. Either way a pretty cool little device, not bad to have in the car if you have an aging vehicle. Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 13, 2012 Author Report Share Posted August 13, 2012 DIngo can you confirm what kind of engine loads you see on the Edge? I seem to be seeing higher numbers than I would expect. I did find a few sources that indicate there are different ways this is calculated and there are two different PIDs for this but either way on fairly flat roads moderate acceleration would indicate 100% even when it felt like the engine had more to give. Idle was higher than expected too...I thik the Audi was less than 5% where I think the lowest I saw on the Edge was maybe 20 something. Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 13, 2012 Report Share Posted August 13, 2012 I never looked that closely, but it's all adjustable. Quote Link to comment Share on other sites More sharing options...
wlepse Posted August 13, 2012 Author Report Share Posted August 13, 2012 Well at first it was way the hell off reading 100% almost all the time, then I realized the displacement was set for the Audi. Once I changed that it was much better but still pretty high. I did see a bunch of threads on various forums where people were stating it was reporting high but nothing on the Edge. This is one explaination I found: http://obdcon.sourceforge.net/2010/06/about-pid-calculated-load-value/ based on that I would guess the Ford is using PID43 since it is based on air mass per stroke and as mentioned above it changed with displacement. Just wasn't sure what was typical in the way Ford is calculating it. Quote Link to comment Share on other sites More sharing options...
je3169 Posted October 11, 2012 Report Share Posted October 11, 2012 Hey Dingo what is the name of the app you are using. Thanks John Quote Link to comment Share on other sites More sharing options...
wlepse Posted October 11, 2012 Author Report Share Posted October 11, 2012 Torque Quote Link to comment Share on other sites More sharing options...
rsucre Posted July 6, 2013 Report Share Posted July 6, 2013 I have Actron U-Scan. It is a new bluetooth scanner that is fully compatible with iPhone. It recognizes the Edge and works very well. You can buy a software module (in app purchase of aprox. $15) and get real-time data from most sensors (RPM, voltage, speed, oxygen sensor, etc.). There are other in app purchases for advanced ABS diagnostics (which I have not tried). So far, so good. Quote Link to comment Share on other sites More sharing options...
Drive XR7 Posted July 6, 2013 Report Share Posted July 6, 2013 I have one and use it with Torque. Don't know why I didn't buy one before. Very useful. My EcoBoost pushes like 16lbs of boost.. was surprised to see that much. Quote Link to comment Share on other sites More sharing options...
Dingo Posted July 16, 2013 Report Share Posted July 16, 2013 Less money, smaller, and in America... Http://amazon.com/dp/B008U1MOM8/ref=cm_sw_r_an_am_ap_am_us?ie=UTF8 Quote Link to comment Share on other sites More sharing options...
