Hey Everyone,
I've had a 2013 Edge for two months now, and it seems to me that the headlights are kind of shitty. And by shitty, I mean they're weak/soft/vague... basically NOT VERY BRIGHT.
Had anyone else suspected that. I'm even thinking of going out and buying some other bulbs to try, but I have the feeling the bulbs for an Edge aren't just $10 bulbs.
Any comments are appreciated.
Andreas
Lac du Bonnet, CANADA
Ripper, The bulbs in the edge are the brightest non hid bulbs you can get. They are 9012 HIR1's, running at 55 watt. A couple of things, If your new to projectors, they tend to take some time getting used to. Their beam is not typical of a halogen reflector and can seem to be dim based on the weird beam shape. Also, we just bought a 2013 last week and noticed the headlights are aimed WAY too high. May be something to look at. Should be 2 inches below the center of the projector lens at 20 feet. That also being said, my wife hates the dull yellow color so will be installing a 6k 55 watt HID system in it shortly. ( This will also make it a little brighter)
  • 3 months later...
I also noticed our headlamps are aimed too high. On low beam going down the highway I must have had 1/2 a dozen cars flash me going down a 5 miles stretch. When the high beams don't seem to make a difference in brightness, you know there must be an issue. I haven't contacted ford yet about it, but I'm going to have to do something. I'm wondering if it's because we have the sport model and it's slightly taller with the bigger wheels and they didn't adjust the headlamps.
  • 10 months later...
Hello to all of you frustrated with the less than spectacular performance of the headlights. I have owned my 2013 Ford Edge SEL for three months now and I just cannot get used to the headlight brightness (or rather, dimness) and the beam pattern. I think I could live with the pattern if the lights were just brighter. I have done a modest amount of searching online and talking to my service representative and parts department guys at the Ford dealership and I have learned that perphaps the Sylvania SilverStar Ultra 9012 is brighter than the OEM bulbs. Do any of you know this to be case? The online Sylvania bulb replacement guide indicated part number 9012, but I have not yet found it at any parts store. Do any of you know where I can purchase the Sylvania SilverStar 9012? The Ford parts guy sent me to Walmart and, in fact, they have SilverStar and they, in fact, show that 9012 is the replacement bulb, but there are none on the display rack and the parts guy had never heard of the 9012. Thanks in advance for any suggestions.
RadioBob
I have used the silverstar's in my previous cars and definately liked the output, much better than stock. I know at least with HID upgrades you can use a 9005 or 9006 size bulb as a replacement for the 9012's as I can't seem to find the silvestars in that size either.
Honestly though, if you don't mind a little extra work on the installation for the price I would go with a full HID kit from DDMtuning.com. The 35w kit is only $29.99 + shipping and you will have a much better output than the silvertars alone which run around $35 depending on where you shop.
-Russ
I haven't heard antyhing of that nature with HID's in these housings. Now I have heard of that if you were to install those horrible blue bulbs into a regular housing, i.e. ricer civic upgrades, but these are safe. Lots of people on here have the same HID kits or others and have not had any noted issues. I've had mine installed for about 6 months and going strong, others have had then for much longer.
Don't confuse "xenon" bulbs with HID ballasts and bulbs. HIDs run the same wattage (and really close heat/temp) as stock incandescent,
The crappy aftermarket xenon bulb are essentially blue coated bulbs (in order to created the white bluish light effect of HIDs). They then use higher wattage bulbs (65-85W) to compensate for loss of light/lumens caused by the blue coating.
HIDs won't melt housings (you still need to be cautious if your installing in a 15w fog light housing), but doubling the wattage with crappy xenon bulbs will.
I've been using 55w HIDs for over a year and a half with zero issues.
I don't mind just changing bulbs, but if other gear (ballast units?) needs to be added, I'm losing interest.
If you don't want to do any work then a HID upgrade is probably not for you. No matter what you have to mount a ballast and route the wires to and from it for the bulb/power. I think most of the direct plug in systems are having difficulty igniting so the only choice is to run a direct to battery wire and use a relay which means you have to route those wires from the battery/fuse box to each side which means a long wire across the front.
Basically, if you want an effortless upgrade.... forget it. I did a full write-up on my upgrade on this board and you will see to do it VERY well takes time. If I just half assed it then it would still have taken a couple of hours.
Edited by 12Edge
Thanks 12Edge.................I'm just not equipped to do this kind of work (no garage..........no real tools.........no competency), so I'm glad I asked the questions...........
I may purchase the parts and find a respected electrics shop and pay to have them installed, so just finding the best solution is a step forward for me.
Dave
You're talking yourself out of an excellent lighting upgrade.
I did aftermarket hid cars on my last three vehicles. My first was in my parking lot in front of my first apartment (2001!).
You don't need any tools. On some kits, the 9006 bulbs are a bitch to get in, but others have reported that the 9005 bulbs are much easier (no difference in performance). The only extra things you need are 3M dual lock fasteners (high strength Velcro) and some zip ties).
This assumes you go with a 35w kit and no harness. It's completely plug and play (30 minute job).
If you decide to go with a wire harness/relays then you only need a wrench (adjustable) to loosen the battery terminal connections in order to secure the wire harness.
It's so much easier than you think. 12Edge did an elaborate setup (which looks great BTW). I took the easier method and purchased the TRS morimoto kit, which includes everything you need (and is fantastic quality).
We can all walk you through it. It's worth an hour (being conservative) and $120 (max, there are cheaper kits) for the HUGE lighting improvement.
Thanks for the pep talk..............I can do it, once I have the right gear................sounds like the best solution might be the TRS morimoto kit and follow 12Edge's instructions. I just tried to find his instructions and can't locate...................can someone give a link so I can print the his instructions off?
Dave
Mine wired in directly to the fuse box, no battery connection and I put most of the harness inside the lamp housing itself. I also removed both headlights to do it. It was pretty intricate. You can just attach the relay and ballast to the inside body panel or side of the lamp housing. I noted in my install that I could have probably easily just poked a hole in the side of the lamp housing where the ballast is mounted and used a plastic push pin from an auto parts store.
It really is a GREAT upgrade to the vehicle and seriously improves ability to see at night. I know Dan with http://www.daytimebrightlites.com/ posted a youtube video on his plug & play 35W kit install with no harness but I don't know where I saw that link now.
Here is the link to my install:
http://www.fordedgeforum.com/topic/13572-my-hid-upgrade-with-close-to-factory-lookoperation-for-80/
As Droth said, if you have any questions or concerns post them here and we will do our best to offer help, tips and suggestions.
Edited by 12Edge
