  On 7/30/2012 at 7:14 PM, fishx65 said:
Gonna pull it this weekend and see if there is a good way to shim the housing. Thinking I might be able to slip a washer on a mounting stud or something. Anyone here ever pull a headlight housing out on a 2011+?
Hi fish. :D Just as an FYI, so you know what you are in for - To remove the headlight housings, you must first remove the front bumper cover/fascia.
EDIT - Just realized I was answering a question in the Edge forums (thought I was answering in the Fusion forums), so while this information is accurate for the Fusion, I am not 100% sure it is accurate for the Edge. If someone supplied information otherwise, i will edit out the incorrect information.
Thanks and good luck. :beerchug:
Edited by bbf2530
