Torontoguy Posted July 13, 2012 Report Share Posted July 13, 2012 What's up everybody I've got a 2011 Limited and just recently the Door Ajar warning will not turn off despite closing the door with good force or opening and closing multiple times. It would appear the Door Ajar switch is stuck in the "door open" position. Does anybody have any info on where to find or access this switch? Dealer wants $500 for the repair! Unfortunately I'm out of warranty as I do quite a bit of driving for work. I've done some quick reading about this issue and found that the switch is part of the latch mechanism? Can anyone confirm this? Thanks so much! Ps. Here's the Edge enjoying some Summer fun. 1 Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted July 13, 2012 Report Share Posted July 13, 2012 Sweet picture, did you try spraying the latch with WD-40? Maybe it's just sticking. Quote Link to comment Share on other sites More sharing options...
phlatlander Posted September 3, 2012 Report Share Posted September 3, 2012 Sorry Torontoguy, I think you're out of luck. The problem is likely a switch with faulty circuitry. We had the same problem and the dealer replaced the part. I didn't even get out of the parking lot and the "new" part didn't work. They replace it again and apparently the mechanic said, "well the first one fit sort of funny." Took a couple of hours to replace too! 2 Quote Link to comment Share on other sites More sharing options...
Berry3 Posted September 18, 2012 Report Share Posted September 18, 2012 I am having the same problem. Quote Link to comment Share on other sites More sharing options...
milktruk Posted September 19, 2012 Report Share Posted September 19, 2012 Used to have that problem, too. Sprayed some WD40 on the latch - problem solved. Quote Link to comment Share on other sites More sharing options...
Cellbine Posted September 19, 2012 Report Share Posted September 19, 2012 Taking my car to the dealer on the 27th for this same problem. WD40 didnt work for me. Pretty sure im still under warranty so hopefully this will be painless. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted September 20, 2012 Report Share Posted September 20, 2012 Hope that the problem gets corrected by your dealer. Let us know what the results are. Quote Link to comment Share on other sites More sharing options...
Dingo Posted September 20, 2012 Report Share Posted September 20, 2012 Home Depot sells a dry lube spray with PTFE. Buy it. Use liberally on everything. Quote Link to comment Share on other sites More sharing options...
nikkojuno Posted September 20, 2012 Report Share Posted September 20, 2012 I had the same issue last month. Took it to the dealer and had the door module replaced under warranty. It took about 2 hours to replace. Quote Link to comment Share on other sites More sharing options...
Cellbine Posted September 20, 2012 Report Share Posted September 20, 2012 I had the same issue last month. Took it to the dealer and had the door module replaced under warranty. It took about 2 hours to replace. Awesome, Hope mine goes as smooth as yours went. Home Depot sells a dry lube spray with PTFE. Buy it. Use liberally on everything. Would love to, live in Germany. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 20, 2012 Report Share Posted September 20, 2012 Home Depot sells a dry lube spray with PTFE. Buy it. Use liberally on everything. Everything? Quote Link to comment Share on other sites More sharing options...
Dingo Posted September 20, 2012 Report Share Posted September 20, 2012 I'm not sure if it breaks down latex... 1 Quote Link to comment Share on other sites More sharing options...
arnesr Posted December 7, 2012 Report Share Posted December 7, 2012 I had the door ajar issue as well with my 2011 Edge. They told me they replaced the latch. I had to take it back as when they put it together the lock was jamming. Working now. Seeing this post, it seems to be a common problem, perhaps they need a recall to fix the issues. Quote Link to comment Share on other sites More sharing options...
MickeyCondon Posted December 10, 2012 Report Share Posted December 10, 2012 bringing mine in today for this same exact problem. Quote Link to comment Share on other sites More sharing options...
MickeyCondon Posted December 19, 2012 Report Share Posted December 19, 2012 and they wanted $110 diagnostic fee to even look at my door because I don't have an extended warranty on my 2011 w/50,000 on it.... Quote Link to comment Share on other sites More sharing options...
PrinzII Posted December 19, 2012 Report Share Posted December 19, 2012 I am getting the Driver Door Ajar warning lately. I am thinking that I may have to take mine in for that as well. Quote Link to comment Share on other sites More sharing options...
chiefc2 Posted December 23, 2012 Report Share Posted December 23, 2012 My 2011 limited just started doing the same thing. I need to slam the door to get the warning light to go out. Does anyone know if there is a TSB on it or what the problem really is ? Quote Link to comment Share on other sites More sharing options...
Edge_Beast Posted December 25, 2012 Report Share Posted December 25, 2012 My 2011 limited just started doing the same thing. I need to slam the door to get the warning light to go out. Does anyone know if there is a TSB on it or what the problem really is ? No TSB that I am aware of. The problem lies within the door latch. It needs to be replaced. Had mine replaced not too long ago. Problem solved Quote Link to comment Share on other sites More sharing options...
snaik69 Posted January 29, 2013 Report Share Posted January 29, 2013 Same prob here. Also, when door is successfully closed it sometimes becomes "ajar" on its own, causing my alarm to go off! Very annoying. Off to the stealership! Quote Link to comment Share on other sites More sharing options...
chiefc2 Posted January 29, 2013 Report Share Posted January 29, 2013 I went to the dealer and had the door latch replaced. It cost me $247.00 because it was out of warantee but the problem was solved. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted January 30, 2013 Report Share Posted January 30, 2013 Bummer that it was out of warranty, but at least it's fixed. Quote Link to comment Share on other sites More sharing options...
MickeyCondon Posted February 21, 2013 Report Share Posted February 21, 2013 Hey all, Can everyone go to www.safecar.gov and report it and maybe we can either get some of you your money back and some of us this repair taken care of for free. Anyone else have any thoughts. Quote Link to comment Share on other sites More sharing options...
MickeyCondon Posted February 22, 2013 Report Share Posted February 22, 2013 Hey all, Can everyone go to www.safecar.gov and report it and maybe we can either get some of you your money back and some of us this repair taken care of for free. Anyone else have any thoughts. I talked to my local service guy and he seemed like a good dude. He told me to call Ford directly and report this. The guy at Ford said that if I did get this fixed to save the receipt in case it does become a recall/TSP issue. If you guys could call 1-800-392-3673 then 1, 4, 4 (if my memory serves me correctly) and it will be put into their system. Takes less than 5 minutes. Hopefully in the future it will be taken care of. Thanks guys! Quote Link to comment Share on other sites More sharing options...
hunter14 Posted May 23, 2013 Report Share Posted May 23, 2013 I had the same problem, it starting coming on intermittently and then constantly. My car is out of warranty and I didn't want to pay for a new latch so I took the door apart to try and find the problem. I found that the resistance through the switch when I closed the latch was varying between 3-10 ohms and the door ajar light would only go off when it went below 3 ohms. So something in the switch is creating poor contact. I liberally sprayed an electronic part cleaner on the switch and the problem is resolved at least for the last few weeks. Not a single problem yet. If you want to try this I found out you don't have to take the whole door apart. If you remove the Top Inboard Screw that holds the latch mechanism on you can use a 3-4" straw to spray inside the latch and clean up the switch. The switch is buried deep into the latch so you should get the straw on the cleaner deep in there and work it back and forth. Then put the screw back in. Hope people find this works. If the problem is that dirt gets inside there, WD-40 might help it build up worse, so I just used the electronics parts cleaner. 5 Quote Link to comment Share on other sites More sharing options...
normcloutier Posted May 24, 2013 Report Share Posted May 24, 2013 Looks like they haven't fixed the problem at factory yet because I just had the drivers door latch changed on my 13 SEL. Quote Link to comment Share on other sites More sharing options...
