Edgely Posted June 24, 2012 Report Share Posted June 24, 2012 Hey all. So I've got a 2007 SEL+ (limited) with the upgraded stereo (sub 6 disc changer) and having problems with the CD changer. Specifically, I cannot eject the one disc that's in there. When I press eject, the stereo says "moving to disc 1" makes some noise like it's trying to move the magazine to the right slot then stops. It makes this noise about 4 times with a pause inbetween each and finally says "CD read error". Has anyone else had this problem? Is my CD changer pooched? Can anyone point me to a write up of how to remove the stereo? Thanks in advance. Edgely. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted June 24, 2012 Report Share Posted June 24, 2012 (edited) I had this problem when I had my '06 Explorer. The dealer said it was because some CD disc's are a "hair" thicker than others. What I had to do when a disc would not eject, is when you hit eject, and it appears that the disc is trying to come out, was to take another disc, and insert it slightly in the slot, towards the bottom of the opening, to help guide the "stuck" CD to eject. It worked every time. With some CD's, I had no problem,and others would give me the same problem that you are describing. Hope this works for you. Joe Edited June 24, 2012 by JOEHIO Quote Link to comment Share on other sites More sharing options...
