jck7 Posted June 14, 2012 Report Share Posted June 14, 2012 Hi everyone, I just purchased a 2010 MKX limited edition, i really like the car, now i want to put nice aftermarket wheels on it. I am looking to go on 22's or 24's. I want wheels that will look big, nice and clean. I do not want wheels that are too big and wide so it will affect the car by rubbing or the wheel will get out of the fender like theres a wrong offset and the wheels look too big for the car. I've seen 24's on MKX before but didnt know if it required modification. Anyway my last question is try to help me, if you have picture that even better, and if you can give me both specs, like the wheels size i need, tire size, offset i will really appreciate. ( a lowering kit is also an option in my mind ....... so it might be something to consider ) Quote Link to comment Share on other sites More sharing options...
jck7 Posted June 14, 2012 Author Report Share Posted June 14, 2012 i found those specs is that true ? 2010 Lincoln MKX Specs Bolt Pattern: 5x114.3 | Center Bore: 67.1 | Hardware:12x1.50 Lug | Offset: 34-45mm Common Tire Sizes: 18 inch: 255/60-18 19 inch: 255/55-19 20 inch: 255/50-20 22 inch: 265/35-22 I just didnt found anything for 24's and offset from 34 to 45 is something really wide someone know the perfect one ? 265's tires for 22 inches wheels is not too wide ..... ? No rubbing on full turns ? Quote Link to comment Share on other sites More sharing options...
PrinzII Posted September 23, 2012 Report Share Posted September 23, 2012 Your best bet would be to go 22" versus 24". Case in point, the 2011-up Edge Sports are on 22s with no ill effects. There is a picture of an Edge on this site with 24s and he did have to do some modifications to get them to fit. Quote Link to comment Share on other sites More sharing options...
JT58 Posted September 24, 2012 Report Share Posted September 24, 2012 We have a 2010 Edge with factory 22 inch wheels. While they look really good and don't really stick out they are HEAVY. The best recommendation I can give is look for light weight wheels, if you can find them. The extra added weight of the big wheels really slows down acceleration. As good as they look, if I had to do it over again I probably would not opt for the big wheels. Quote Link to comment Share on other sites More sharing options...
Mike Monaghan Posted September 25, 2012 Report Share Posted September 25, 2012 I recomend u go to a local wheel store & get a 24 rim w tire test fitted. I got 22s for my Edge & totaly regret not getting 24s. Quote Link to comment Share on other sites More sharing options...
DFallenAngel Posted February 7, 2013 Report Share Posted February 7, 2013 Interesting.... Quote Link to comment Share on other sites More sharing options...
