thirdgenlxi Posted May 29, 2013 Report Share Posted May 29, 2013 Just turned 111k. Spark plug replacement at 101k. Radiator fan control module is acting up now. Radiator fan in high all the time. Replacing the module is easy, replacing the entire fan assembly will be an adventure. Everything else is operating at specification [or so it seems...] The whole fan is crazy easy to replace..... seriously maybe 15 mins doing it the slow way with hand tools, lol. And don't drain the coolant like the manual tells you to, don't need to.... bungee cord the wiring harness and upper rad hose back out of the way, take the little bracket off the drivers side that the bolt for the airbox goes into (take airbox out too, of course), and you've got plenty of room, fan will pull right out no problem 2 Quote Link to comment Share on other sites More sharing options...
Stang93 Posted October 8, 2013 Report Share Posted October 8, 2013 Just thought I would keep this going, I was curious how many miles people had on their edge so I joined the forums. I currently have an 07 SEL AWD, with 282,808miles and still going strong! Knock on wood! Bought it in 3/09 with 36,000 miles on it. Just bought my 4th set of tires, just had to replace my brake booster last week, lower control arm on front right 3 weeks ago, and over the last 4 years, just a battery, brakes, speed sensor, 1 wheel bearing and hub, and oil changes. Still on factory spark plugs, and still getting 23mpg, did have some tranny slipping earlier this spring,I added some lucas tranny fix, it continued to slip for 15,000 miles and has been fine ever since. 3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 8, 2013 Report Share Posted October 8, 2013 Are you sure that's not in KMs??? Seriously, that is actually a very reasonable service history. Factory spark plugs, wow! Quote Link to comment Share on other sites More sharing options...
Stang93 Posted October 8, 2013 Report Share Posted October 8, 2013 Ha, yes it is miles. I drive about 55,000 miles a year. Only have had 1 alignment too! I also own a 2010 limited edge as well(wife's car) love these edges 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 8, 2013 Report Share Posted October 8, 2013 We should create an Edge Hall of Fame just for examples like this 3 Quote Link to comment Share on other sites More sharing options...
Stang93 Posted October 8, 2013 Report Share Posted October 8, 2013 I have used motorcraft synthetic blend 5w20 since I have owned it. Wonder if ford does any thing like Quaker state does with their cash back for loyal users, and something with buying your car after it has x amount of miles on it. 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted October 10, 2013 Report Share Posted October 10, 2013 (edited) 2008 Edge SE: Bought brand new and put 105,600 on the clock before trading it on the 2011 I have now. Got $12,000 for it. 2011 Edge Limited: Bought with 18,199 on the clock and it now has 59,000. Edited October 10, 2013 by PrinzII 1 Quote Link to comment Share on other sites More sharing options...
stang066 Posted October 30, 2013 Report Share Posted October 30, 2013 I know it's an old topic but we have 180k on our 07 SEL plus that we bought in 2011 with 150k. WeWe are second owners and the prior owner had all of the work performed at the dealer we purchased it from so the records are great otherwise we would not have bought it. I've put front pads on it and and just replaced the battery. it needs new tires and developed a torque converter shutter shortly after we bought it, otherwise no problems until last week. My wife was driving it home and experienced all the symptoms others have described associated with a P0720 output shaft speed sensor malfunction. So I've been looking to see how many miles owners have reached before needing their trans worked on or remanufactured? I say remanufactured because of the miles we have and plan on puting on it. The only things we have done is a steeds strutt tower brace, ss front brake lines, and 3M 30% ceramic all around and crystalline 70% on the windshield and vista roof. Quote Link to comment Share on other sites More sharing options...
macbwt Posted December 9, 2013 Report Share Posted December 9, 2013 Just thought I would keep this going, I was curious how many miles people had on their edge so I joined the forums. I currently have an 07 SEL AWD, with 282,808miles and still going strong! Knock on wood! Bought it in 3/09 with 36,000 miles on it. Just bought my 4th set of tires, just had to replace my brake booster last week, lower control arm on front right 3 weeks ago, and over the last 4 years, just a battery, brakes, speed sensor, 1 wheel bearing and hub, and oil changes. Still on factory spark plugs, and still getting 23mpg, did have some tranny slipping earlier this spring,I added some lucas tranny fix, it continued to slip for 15,000 miles and has been fine ever since. Glad to hear another person is in the 200k area. You have a year head start on me, but I think I can get to the 280's by next christmas. I plan on making this Edge go for as long as I can barring Tranny Failure or Engine failure. The rest can usually be repaired economically enough and better than buying a new car. Quote Link to comment Share on other sites More sharing options...
Ford4x4life Posted January 13, 2014 Report Share Posted January 13, 2014 Just purchased a 2011 Limited AWD 302A with 87k. Has pretty much everything and currently in love with the thing (hopefully nothing happens) purchased extended warranty in any case something does. Quote Link to comment Share on other sites More sharing options...
ehstaley Posted January 23, 2014 Report Share Posted January 23, 2014 I just bought my wife a 2009 MKX Ultimate FWD with 90k on it. The exterior looks brand new and as does the interior minus a couple scratches in some plastic. So far, it drives great and appears to have been taken care of. Quote Link to comment Share on other sites More sharing options...
Stang93 Posted February 18, 2014 Report Share Posted February 18, 2014 Update***** Just turned 300,000 miles today, still going strong! Just drive home in a freezing rain/snow storm, handles like it did 5 years ago! 3 Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted February 18, 2014 Report Share Posted February 18, 2014 Update***** Just turned 300,000 miles today, still going strong! Just drive home in a freezing rain/snow storm, handles like it did 5 years ago! That's awesome! You got any pictures? Glad to hear she's still going strong and treating you well Makes mine look young, at only 121k, hahah 1 Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted February 18, 2014 Report Share Posted February 18, 2014 Well my 2012 is almost at 5K lol., But I bought mine because a sales rep. that visits my store has an 07 AWD with over 300K , but he just replaced his transmission. He carries 500+ lbs of of samples all the time too. He told me that he always followed the severe use maintenence schedule. 1 Quote Link to comment Share on other sites More sharing options...
Stang93 Posted February 20, 2014 Report Share Posted February 20, 2014 That's awesome! You got any pictures? Glad to hear she's still going strong and treating you well Makes mine look young, at only 121k, hahah Quote Link to comment Share on other sites More sharing options...
Stang93 Posted February 20, 2014 Report Share Posted February 20, 2014 Here is my 300,000 mile picture, sitting at 300,500 right now. I will have to wash the edge and take an updated picture soon. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 20, 2014 Report Share Posted February 20, 2014 Spic 'n span interior! Congrats on the 300K mark! Quote Link to comment Share on other sites More sharing options...
Brandin Paul Posted February 26, 2014 Report Share Posted February 26, 2014 I have an 2008 ford edge with 126,000 miles on it. Had a transmission lock out at 125.5k miles, just pulled PCM fuse to basically reset it. works fine now. Still original battery. 5th set of tires though. I have continentals on there now. Been on since 68k and still have like 75% tread left. Had a coolant leak at 120k this was a clamp that rusted out. Have a bad valve or lifter tick right now. stll runs and drives great though. On the original brakes as well. (90% of my driving is highway) I have a K&N intake on it now and Magnaflow Cat-Back exhaust. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted February 28, 2014 Report Share Posted February 28, 2014 Here is my 300,000 mile picture, sitting at 300,500 right now. I will have to wash the edge and take an updated picture soon. I am about a year behind ya buddy. 230,000 now and should hit it about this time next year. 1 Quote Link to comment Share on other sites More sharing options...
Stang93 Posted February 28, 2014 Report Share Posted February 28, 2014 Good luck on the miles! It is a goal to see how long this Edge will run! Weekly update 301,780 miles Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 22, 2014 Report Share Posted April 22, 2014 Still kicking it down the road at 236,000 miles. Mostly highway. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 22, 2014 Report Share Posted April 22, 2014 Just let me or fifthranger know where the keys are and we can take turns with it for ya!!! LOL You guys make me feel like I am neglecting my Edge! I'm still struggling to breach the 8,000 mile mark on mine after nearly two years of ownership.Someone could probably steal the thing out of our garage and it could take me a week or more to realize it! Quote Link to comment Share on other sites More sharing options...
frebrd18 Posted July 22, 2014 Report Share Posted July 22, 2014 I bought my 2007 Edge SEL FWD from a private seller in '09 with 10k miles - black with black leather and panoramic roof, Nav and (stock Pioneer?)stereo with sub. I have 94k on it now with no major problems, in fact my wife and I agree that it's the best car we've ever owned. The brakes were not the greatest when we got it, low pedal, long stops times but I took in to Ford under warranty and they bled the system and it was better. Also on the brakes, I replaced the original with EBC green pads (new front rotors) and was very disappointed. They were dirty and responsiveness was mediocre. At 75k I repalced them with Hawk pads all around, new rotors in back, cut original front rotors. What a difference! Not a lot of dust and great stopping feel. Every couple years I clean the roof tracks and re grease them, and dont park under a tree with the roof open. Rear bulbs go every couple years, mositure gets in there. Replaced rear hatch struts at 80k when it sagged and I hit my head! about $60. Funny how you push the negatives out of your mind, but I developed a tranny leak in the cooler on the radiator and didn't have time to do it myself so that was $600. Repalced Tires at 90K with 4 Continental Eco plus 20 245/60R18 and I am really enjoying the ride and quiet. I use Motorcraft semi synthetic every 6000k mostly highway driving. Tranny clunks a little but seems better since I had fluid replaced when cooler was replaced. Great Road trip car, NY to Bar Harbor,ME and Wisconsin through UP of Michigan. I saw that in Consumer Reports the 2007 has had better reliability than the newer models so I guess I got lucky. 3 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted July 24, 2014 Report Share Posted July 24, 2014 I am now at 82k with the 2011 Edge. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 24, 2014 Report Share Posted July 24, 2014 Almost caught up to me in my '07 1 Quote Link to comment Share on other sites More sharing options...
