Sarnano Posted June 7, 2012 Report Share Posted June 7, 2012 Has anyone else noticed that when they turn on the front wipers, the rear wiper comes on for one or two cycles? Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 7, 2012 Report Share Posted June 7, 2012 Haven't seen that but there is a setting to have it sweep if you put the car in reverse and the fronts are on. Quote Link to comment Share on other sites More sharing options...
11edgelimited Posted June 9, 2012 Report Share Posted June 9, 2012 I think it is called courtesy wipe. Should be in the lcd left of the speedo. I don't remember what it is under though. Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 10, 2012 Report Share Posted June 10, 2012 I thought the courtesy wipe was the second delayed wipe after cleaning the windshield. Either way the settings are in the the cluster as mentioned. But if you are seeing the rear wiper go off when you're not in reverse something else is up. Quote Link to comment Share on other sites More sharing options...
