OBDII code P0451 driving me crazy!!!
jaw42885
Need some help. The check engine light came on the morning after I got gas. Checked the code and came up with code P0451. I checked the gas cap and everything was on tight. I didn't over fill the gas. I have no clue where to go from here. Anyone have any suggestions? Thanks for the help. My name is Joey by the way.
Check your gas cap gasket, that's all I can guess. Perhaps the gas cap is cracked somewhere you can't see. Have you cleared the code? Sometimes it requires a few cycles before the computer will clear it.
Edited by cjd3
Sometimes the caps do wear out but see if a local auto parts place can test it for you. If it isn't the cap there is a pressure sensor in there that does go bad on occasion but not sure if this is really a DIY fix. Maybe one of the Ford techs can chime in with the difficulty of replacement if it comes to that.
